Help with Clutch Bleed
Old Aug 26, 2006 | 01:32 PM
1179's Avatar
1179
Cool Help with Clutch Bleed
Broke the plastic end of the master cylinder push rod. Had to replace the master cylinder to get a new one. Went well but only get movement at slave cylinder on last 1/2 of pedal travel, not enough to disengage the clutch. Disconnected line at slave cylinder and good fluid flow. No better. Took off slave cylinder and stroked it--no better. Any ideas. Neither the master or slave has a bleeder screw that I can find
Old Aug 26, 2006 | 02:49 PM
1179's Avatar
1179
More Info
I took the slave cyl off of the tranny again. This time by holding the slave port upwards and stroking completely I got some more air out, but still not enough to get into or out of gear. The clutch finger moves 5/8" from rest to full stroke (what is the spec for this?)( it was only 1/2"), but the pedal still doesn't start feeling resistance until about 1/2 stroke. This truck has 150K on the orginal clutch. If the clutch is shot wouldn't it slip? rather than not engage?
Thanks for your suggestions
Old Aug 26, 2006 | 09:39 PM
Boss429F150's Avatar
Boss429F150
year of truck? my 89 I6 cyl. has the bleeder right on the slave cyl. Sometimes clutches can be a little difficult if there is air trapped in there.
Old Aug 27, 2006 | 08:37 AM
MustangGT221's Avatar
MustangGT221
There is a bleeder screw on the slave cylinder that sticks out of the tranny with a cap on it.
Gravity bleed it through that bleeder.
Old Aug 27, 2006 | 10:05 AM
1179's Avatar
1179
93 F250 Turbo diesel--slave is external, so only connected with the tranny at the mounting bracket, piston rod contacts clutch finger.
Old Aug 27, 2006 | 12:54 PM
MustangGT221
then you may not have a bleeder screw, i duno...i've never done one of those...
Old Aug 31, 2006 | 07:03 PM
Bender1987's Avatar
Bender1987
My 1987 F-350 4 speed has a set screw bleeder, right where the line goes into the slave cylinder, I don't know if yours is the same. It's a real pain in the posterior, and takes a lot more work than bleeding brakes.
templars
1983 - 2012 Ranger & B-Series
Sep 14, 2019 07:42 PM
wallysford
1978 - 1996 Big Bronco
Apr 12, 2017 04:14 PM
reamer
Oct 3, 2016 06:40 PM
newguy399
Jul 12, 2016 11:59 AM
maxride
Oct 1, 2015 07:00 AM
