hard shift into OD
Old Aug 27, 2006 | 12:24 PM
howarda's Avatar
howarda
hard shift into OD
I have a 2000 F350/4wd/v10 with just 60 K on her. Under normal, lightly loaded driving conditions transmission works fine. Under load or even worse under heavy throttle the last shift it makes slams. To smooth it out you have to release the gas but then sometimes that makes it just float between shifts. I asume this is a 4R100 trans? No check engine lights or anything like that. Fluid looks and smells good.
Is there something common like a broken spring that can cause this or am I headed for a rebuild?
I'd appreciate any thoughts. Thanks, Howard
