E4OD fluid?
Old Aug 26, 2006 | 02:32 AM
RandysF150's Avatar
RandysF150
E4OD fluid?
What type fluid goes in a E4OD? Thanks
Old Aug 26, 2006 | 02:43 AM
aurgathor's Avatar
aurgathor
Mercon; and don't confuse it with Mercon V.
Old Aug 26, 2006 | 10:16 AM
projectSHO89's Avatar
projectSHO89
Mercon V is now the factory approved fluid.
Use either.
Steve
Old Aug 26, 2006 | 11:57 AM
aurgathor's Avatar
aurgathor
Regardless, I'd still use a plain Mercon if available, or at the very least, use a dual rated fluid.
I remember two issues attributed to Mercon V years ago when not only it was not a factory approved and recommended fluid, but it was stronlgly warned against:
a) some seals were incompatible with it
b) caused accelerated wear on clutch material
Did E4ODs got suddenly better overnight? Bloody unlikely. Did they change the formulation of Mercon V? Possible, though I wouldn't bet on that.
Recently rebuilt trannies most likely have parts that are compatible with Mercon V, but I can tell you that I'm not putting Mercon V into mine (190k, never rebuilt) unless I can't get anything else.
Old Aug 26, 2006 | 06:20 PM
T18skyguy's Avatar
T18skyguy
If it calls for Mercon R use that. I wouldnt use a dual rated fluid cause Ive heard thats not good for the older E4OD's. YOu cant go wrong if you use what it originally called for.
Old Aug 29, 2006 | 08:09 AM
Casey's Avatar
Casey
Mercon R? Never heard of that one! What is it?
