How warm do rear axles get?
Old Jun 23, 2010 | 04:07 AM
Blue Rebel's Avatar
Blue Rebel
Hey guys, quick question. How warm should the housing for the rear axle get after driving say 10 mi? On both my 89 F250 and my 95 F150 even after a short trip like this the housings are quite warm, almost too hot to hold. Is this right, or should I begin to worry about both my trucks? Thanks for any opinions!
Old Jun 23, 2010 | 02:51 PM
xlt4wd90's Avatar
xlt4wd90
I think getting very hot is expected. After all, the gear teeth surfaces slide across each other under enough pressure to move the truck. The old 9" differentials were the worst due to the placement of the pinion relative to the ring gear to allow for the nose bearing.
If you're concerned, check the vent tube of the case after a drive to see if the lube is burning. The lube will get hot, but it should not burn.
Old Jun 23, 2010 | 04:34 PM
85e150's Avatar
85e150
Too hot to hold after 10 miles?
Making any noise?
Is this at the pinion area? How is it out by the wheel bearings?
What does the oil look like?
Old Jun 24, 2010 | 06:49 PM
Blue Rebel's Avatar
Blue Rebel
Anybody have a rough temp they should be at? 150*? 200*? A temp gun is gonna be my next purchase, and id like to know what i should be aiming for at the diff.
Old Jun 25, 2010 | 12:55 AM
xlt4wd90's Avatar
xlt4wd90
The gears are probably the hottest components, but they do not have any direct contact to any external components. The pinion bearing area may be the most direct. You could check another truck with the same diff for reference.
Old Jun 25, 2010 | 08:53 PM
dustybumpers's Avatar
dustybumpers
they get warm enough to not put your hand on them for very long. make sure the oil is toped off, and change it once in a while.
abe
Oct 12, 2012 12:05 PM
Truckin' Travis
Sep 26, 2012 10:29 PM
drjohn
Jun 2, 2011 01:04 PM
sniperscoutwill
Dec 1, 2010 08:02 PM
oldsub86
1997 - 2003 F150
Mar 21, 2010 09:51 PM
