Looking at an old NP435
Old Jun 29, 2010 | 09:31 PM
Tumblindyce's Avatar
Tumblindyce
When you go to look at a used manual transmission, what do you check for? Should it shift into all gears w/o the clutch(if it's out of the truck)? Thanks.
Old Jun 29, 2010 | 10:34 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Just the trans, or is it still bolted to an engine?
I always like to spin the input/output shafts, and shift thru all gears, listening/feeling for anything that doesn't seem right. If it's loose, flipping it on a side and getting the drain and fill plugs out to look for signs of metal shavings (within reason) is another thing I like to do, as well as a small sample of the lube.
Those checks can reveal quite a bit about the likely condition of the internals.
If it has a removable plate/shift tower, opening it up and having a peak inside can also tell a lot.
Old Jun 29, 2010 | 11:11 PM
Tumblindyce
Thanks...just the kind of advice I was looking for.
Old Jun 29, 2010 | 11:45 PM
85e150's Avatar
85e150
Some info to make sure of which flavor it is, if you have any doubt:
The New Process 435 Transmission - Novak Conversions
Old Jun 30, 2010 | 01:47 AM
Tumblindyce
Thanks, that's a great site. Just to remove any doubt, the NP435 will bolt up directly to a 351W, correct?
Old Jun 30, 2010 | 10:58 PM
85e150's Avatar
85e150
With the correct truck-depth bell.
