any problems with the 4.6 triton ??? - Ford Truck Enthusiasts Forums
Old 01-28-2005, 03:56 PM
JF5speed
JF5speed is offline
JF5speed is starting off with a positive reputation.
Im looking at a 99 with the 4.6 triton and would like to know if this motor has any problems
Thank you
Old 01-29-2005, 12:48 PM
JF5speed
JF5speed is offline
Thank you
if you have had NO PROBLEMS please tell that too
thanks
Old 01-29-2005, 06:06 PM
canuckeh
canuckeh is offline
canuckeh is starting off with a positive reputation.
I own a 97, 4.6 with 235,000 kms, and so far no problems. I dont even need to add oil between changes. So far, i'm happy
Old 01-30-2005, 01:55 AM
JF5speed
JF5speed is offline
MAN thats awsome!!!!!!!!!!!!!! just wondering are you still on the originall fuel pump??????????
Old 01-30-2005, 06:32 PM
canuckeh
canuckeh is offline
Yes I am. Also for a little more info, I installed Motorsport shorty headers and a 3"cat back system at 200,000kms and truck runs better with better gas mileage, and I also pull a two horse trailer alot. I just make sure I do regular maintenance, and I'm hoping for a lot more Ks(fingers crossed)
Old 01-30-2005, 07:35 PM
JF5speed
JF5speed is offline
that sounds real good, now i wonder if you can wear the 4.6 out!!!
Old 09-05-2008, 08:13 AM
latoniatank
latoniatank is offline
latoniatank is starting off with a positive reputation.
we have a 1999 e 150 bought new. Triton 4.6. no problems til now. was running fine til parked. 69000 k. on startup engine started making lifter noise. took to dealer, tech stated timing chains repair $700 that did not fix the problem. Still same noise. Chains are a problem for some of these engines. Tech checked oil pump, no problem, but not getting oil to the heads. any ideas for a solution here?
Old 09-07-2008, 12:25 AM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
#1 make sure your using the 5w-20 it calls for.. start there. lots of people say thats too thin for an engine. they dont tell you that for jokes and giggles . #2 if thats not the issue use some seafoam in the oil ... maybe a dirty lifter?
Old 09-07-2008, 07:59 AM
latoniatank
1999 triton 4.6
Ifound this link I believe sounds like my engine noise http://www.youtube.com/watch?v=0Jj38lAC98M. how much seafoam should I use.
Old 09-07-2008, 08:18 AM
latoniatank
Old 09-07-2008, 01:05 PM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
The 4.6 is a pretty solid engine, being that it was first installed in 1991.
Some small problems, like the "tick" noise from the early PI heads (98/99?) because of not enough cooling around (I think) the passenger-side rear exhaust valve, wearing out the guide.
The only time the timing chains are a concern is when the oil is not changed enough. And when you hit that magic 200K mile mark
But yeah, pretty rock solid for the most part.
Old 09-07-2008, 01:24 PM
latoniatank
triton 4.6
This doesn't sound like a tick, more of a knock in the upper engine.
Old 09-08-2008, 09:07 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
All of the 4.6L's are virtually the same mechanically,with the differences being intake and some accessory drive items. The modular family of engines is very reliable,and mine have all proven that.
'97 Tbird-215K miles on original 4.6L before I pulled that engine for a modified 4.6L for more power.
'98 F150 4.6L-sold it to Dad with ~220K miles on it,and he's still driving it.
'01 F150 4.6L work truck-still going strong with no problems at 189K miles.
I could go on and on,but with proper maintenance,these engines will last longer than you would believe.
JL
Old 09-10-2008, 08:24 AM
aztec12
aztec12 is offline
aztec12 is starting off with a positive reputation.
1998 4.6 with 120k on it.
that's a 10 year old truck and still have the original generator and starter.
only maintenance done to it was a tunne-up at 90k,brakes and a new battery,witch that's normal maintenance.
I change the transsmition oil once a year and also flush the anti-freeze system, but thats about it for this engine.
I guess the most important thing is to change the engine oil every 3 to 5k miles
Old 09-22-2008, 07:37 PM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
only problem i had with mine was the pesky egr ports clogging up....
Quick Reply: any problems with the 4.6 triton ???
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
