Exhaust leak question
Old Jan 19, 2005 | 08:03 PM
1low50's Avatar
1low50
My father has a 02 4.6 with an exhaust leak on the drivers side. I know the heads are aluminum so do I need to de-torque and re-torque the exhaust manifold on when replacing the gasket.What numbers and sequence? Thanks
Old Jan 20, 2005 | 11:27 AM
LxMan1's Avatar
LxMan1
I would first inspect for broken manifold to head studs. This seems to be a common problem on these trucks.
Old Jan 20, 2005 | 10:51 PM
7700Rob's Avatar
7700Rob
I would replace the studs, including the studs from the manifold to the cat pipe. I would recommend NOT using a cheap after-market gasket and hardware. I just did this on my 5.4, and I didn't want to do it twice. As far as sequence and torque, I don't remember the details off hand. I'm sure someone does though! Good luck. Rob
