5.4L Extremely Rough idle, Shutters when accelerating-HELP!
Old Jan 19, 2005 | 08:28 AM
jrode98's Avatar
jrode98
I have a 98 F-150 with 98,000 miles. Bought it with 50,000 miles and I have never had any trouble until last night on the way home when all of the sudden when I would step on the accelerator it would shutter. When in idle it runs extremely rough, entire truck shakes, but does not die. In park, when I step on the acceletor it shutters in low rpm's then runs fine in high rpm's. Any ides of the the problem?
I grew up around older vehicles that you could work on, and to me it sounds like timing, spark plugs or carb needs adjustment, but with new trucks I need lots of help.
Thank you in advance for the help,
Jason
Old Jan 19, 2005 | 05:51 PM
f-150 hot rod's Avatar
f-150 hot rod
shutter
It sounds as though one of the coils is bad. The 5.4L has individual coils on each spark plug. Is the check engine light on? You may have to take it in to the dealer to have the computer scanned.
Old Jan 19, 2005 | 06:36 PM
LxMan1's Avatar
LxMan1
It is due for a tune-up anyway. Install new Motorcraft or Autolite Double platinum plugs. If the MIL is lit, a quick scan will tell you which cylinder is misfiring.
Old Jan 21, 2005 | 09:13 AM
adamswi's Avatar
adamswi
Mine did the same thing. Turned out to be the EGR valve. They cost about $75 everywhere I checked. One way to check...remove the EGR vavle and cover the throttle body intake and exhaust tube hole with your hands, while an assistance starts your truck. Make sure you have a good seal to avoid vaccum leaks. If your truck runs fine, you know it is the EGR. Worked for me.
Old Jan 29, 2005 | 11:13 PM
Born2DriveFords's Avatar
Born2DriveFords
i had this similar problem, does your check engine light come on and off? if so it sounds like a bad coil pack
Old Jan 30, 2005 | 08:48 AM
cantrma's Avatar
cantrma
jrode, Many things could give the symptoms you're describing. A coil pack seems unlikely because the engine ran fine as the RPMs picked up. The EGR is likely. A big vacuum leak is likely. I wouldn't run out and buy parts until I knew what it was. If I couldn't determine what it was, I'd get it diagnosed.
Old Jan 30, 2005 | 09:59 PM
Wayfarer's Avatar
Wayfarer
Try a fuel additive
I was having a very similar problem with my 2001 F250 5.4, I thought my trans was shot for sure. Then a friend suggested putting a fuel system antifreeze and cleaner in the fuel. So I put a bottle of Prestone Cold Start in the tank and the problem cleared up with in 5 miles of driving. I am also going to change the fuel filter tomorrow, and probably plugs as well.
I hope this helps you, Pete
Theholler
May 28, 2016 04:18 PM
scantrell
Jan 19, 2016 08:01 AM
NC-Travis
Aug 11, 2013 05:43 PM
dines78
Dec 10, 2012 07:35 AM
jstanley
Dec 28, 2011 05:55 AM
