another missfire ?
Old Jan 8, 2006 | 11:28 PM
orange390's Avatar
orange390
another missfire ?
From everything thing I read FTE is place to go if you need some help and I do. I have a '00 E350 box van w/5.4 125k recently tuned it up plugs/pcv/fuel filter/plug boots. It was missin' terrible before and ran great after for a little bit but then it started missin' agian. I checked the codes and it showed a missfire in #1 and #8 both showed signs water in the hole so swapped in new cop's but it was the same thing but now #2 and #5 I don't remember any moisture here. a couple things I'm wondering is I put in regular old Autolites. Are these engines sensitive to the type of plugs I have seen a couple of GM's that didn't like anything but AC platinums and the cat stinks it stunk before and stinks now. Any help or advice would be big help.
Old Jan 9, 2006 | 08:02 PM
orange390's Avatar
orange390
turns out those darn COP's were breaking down when it got hot. didn't put it together untill the weather cold agian and it took awhile to warm up and start missin
Old Jan 9, 2006 | 10:43 PM
LxMan1's Avatar
LxMan1
I'm guessing you got it fixed? Yes these ignition systems prefer double platium Motorcraft or Autolite plugs.
