4.6 / antifreeze
Old Jan 11, 2006 | 08:39 PM
pacesetter's Avatar
pacesetter
4.6 / antifreeze
Great site!! New poster here. Looking for info.
I have 98 f150 4.6,163k,burning a/f on start up only. Misses for a minute or two then clears up. Not adding alot of a/f to coolant jug but some. Been a mechanic all my life [47yrold] but i've never been into a triton motor before. Thats one of the reasons for buying it. Do these engines have intake/gasket problems as I have seen with the competion.
Old Jan 12, 2006 | 06:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
..See you on the boards.
Old Jan 13, 2006 | 04:30 PM
pacesetter's Avatar
pacesetter
Thanks for the welcome...
Old Jan 14, 2006 | 12:59 PM
LxMan1's Avatar
LxMan1
Could be a possible cracked intake manifold or a slight head gasket leak.
Old Jan 14, 2006 | 04:52 PM
pacesetter's Avatar
pacesetter
Thanks for the reply... I'm hoping its not head gasket... Guess i'll just have to pull intake off and look it over...
Old Jan 14, 2006 | 08:53 PM
LxMan1's Avatar
LxMan1
Check the front crossover.
Old Jan 14, 2006 | 10:22 PM
krewat's Avatar
krewat
Pull the plugs, and see if you have coolant (or just plain messy plugs) in #1 and/or #5.
That would be the coolant crossover on the intake leaking into the intake ports.
Maybe you have a heater hose leaking right onto one of the plug holes, that's usually #4... check all the plugs anyway, just in case it's not something major
You might want to get the misfire counters read. That'll help narrow down the problem, at least.
Old Jan 15, 2006 | 12:59 AM
pacesetter's Avatar
pacesetter
Angry
So is it safe to assume if its intake problem #1 & #5 would be getting a/f ? If so I can pull those two and presurize system to see if a/f is there.
I have scan tool at work, it doesn't miss long enough to set a code, but it does set a code. Can't remember # right off hand but it says gross vacum leak detected. Sometimes I reset it sometimes it clears it self.
I know its not heater hose problem its inside not outside....steams out the exhaust and the sweet smell for about 2 mins. upon start up after sitting overnight or after work.
At my day job I"m a tech. So you know how I feel about working on my own stuff ?
JrSVT
New Member Introductions
Jul 16, 2013 09:29 AM
nasty_nate_
May 8, 2013 01:24 PM
snakedoc
Ford Truck Parts for Sale
166
Apr 30, 2013 08:01 PM
Onefast96svt
Apr 4, 2013 10:46 AM
five.fold
Modular V8 (4.6L, 5.4L)
22
Aug 25, 2012 10:54 AM
