Better heads
Old Jan 6, 2006 | 01:47 PM
marv02's Avatar
marv02
Better heads
I have a 2002 F250 with the 5.4 I just blew a spark Plug agian It now back at the dealer getting fixed Its still under warranty at least for now THANK YOU.
Is there a better after market heads for this motor or a good fix for FORDS Spark plug blowing heads.
Or is there a recall no one telling me about for the comon head breakage.
Besides the cold engine knock during start up every one says is normal for the 5.4 it's been a good motor with 82.000 miles on the clock.
My old 1999 Expeindtion with 5.4 motor with 130.000 miles when I traded it in. Did not knock at all but used oil and did not blow plugs like this 5.4 in my 2002 F250 did 1999 had better heads on them ?.
One more when I rebuild this motor is they long skirt pistons I can put in the motor to get rid of the cold strat Knock, this rebuilding will be couple years from now.
I am planning to keep this truck for a long time any help would help.
Old Jan 6, 2006 | 07:49 PM
kspilkinton's Avatar
kspilkinton
Check out the sealed power brand for the long skirt pistons. There are a few aftermarket head builders for the mod motors. Remember a 2V 4.6 head will fit a 2V 5.4 block... so many Mustang heads are useable on your truck.
-Kerry
Old Jan 6, 2006 | 07:53 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I think the 99 and 02 heads are basically the same. In 03 they went to 8 threads in the head versus 4 threads in 99-02.
Old Jan 6, 2006 | 09:54 PM
marv02's Avatar
marv02
Will 03 heads fit a 02 block
Will 2003 heads fit 2003 block are they bolt on or lkots of mods.
Old Jan 6, 2006 | 10:13 PM
97Centurion
Rub my Belly
The 03 heads will fit the 02 block with no mods I believe. Basically all the heads from 99-03 (5.4&4.6) are interchangeable.
Old Jan 7, 2006 | 03:50 PM
kspilkinton
Here's a link I found... check out the interchangability and such-
http://www.musclemustangfastfords.co...MMFF_MixMatch/
-Kerry
Old Jan 7, 2006 | 09:29 PM
marv02's Avatar
marv02
Thanks for the info
