Base Idle setting on 4.6L
Old Jan 12, 2006 | 11:51 AM
Ray_K's Avatar
Ray_K
Looking for what RPM should be with the IAC unplugged on a 2003 4.6L V8 Explorer to set base idle. Searched and found lots of info on how to set the base idle but nowhere does it say what RPM it is suppose to be at.
Old Jan 31, 2006 | 06:14 PM
tchernosky's Avatar
tchernosky
Idle should be about 6 and 1/2. I am not sure what you mean by unplugged. Usually the engine will struggle and sometimes die if you unplug it
Old Jan 31, 2006 | 07:59 PM
kspilkinton's Avatar
kspilkinton
When the engine is cold it'll idle at 1100rpm with everything plugged in. Mine took two 15 mile trips for the computer to correct the idle after I did a TB swap.
-Kerry
EDsurvivor
Sep 9, 2016 08:52 AM
speakerfritz
Jul 29, 2016 09:58 AM
12longz
1997 - 2003 F150
Apr 30, 2013 06:07 PM
mwf150
2004 - 2008 F150
Oct 28, 2006 08:38 AM
John_E
1997 - 2003 F150
Aug 24, 2004 11:20 PM
