2001 Sportrac leaky rear axle seal
Hi all,My wife's 2001 Sportrac has had a problem with the left rear axle leaking oil..I've replaced the seal 2 times before and replaced the bearing 1 time ..about every 20,000 miles it starts to leak again the axle has a small groove in it(not even finger nail deep) this is getting rather expensive to do,seal,oil,brakes shoes,cleaning of the drum etc. ...what am I missing?Or not doing? Thanks,Longhair!!!
That's a very good question. On my 2000 when I replaced the bearings, seals, and parking brake shoes due to slightly leaking axle seals I removed the vent tube fitting threaded in to the axle and found it to be completely plugged. Between replacing the bearings and seals, unplugging the fitting, confirming the vent tube was clear, and installing new synthetic fluid, my leak was gone and stayed gone for the remainder of the time I owned the truck.
-Rod
-Rod
If the vent is clean, then the problem is the small groove in the axle. YOu have several options, you can use a double lip seal, install the original seal but dont push it in the last 1/8 inch, or use a speedy sleeve on the shaft which is a very thin stainless sleeve you glue to the shaft and the seal will run on that.
Furyman
12-01-2011 08:43 AM
fordnut66
16
05-14-2009 04:34 PM
rriveroll
06-15-2008 04:51 PM
hortusthird
03-13-2006 05:04 PM
