Coolant Filter
Old May 8, 2014 | 07:59 PM
cornstar6207's Avatar
cornstar6207
Coolant Filter
I have a Sinister coolant filter on my 6.0. I use Wix filters, and have been using the Wix filter with coolant additive in it. Is this o.k.? Or should I be using the plain filter. Thanks in advance for all answers, advice and opinions.
Old May 8, 2014 | 09:18 PM
Ford_Fan1's Avatar
Ford_Fan1
what do you mean by coolant additive? You do not want to use a charged filter. Here are some different part numbers you can use for coolant filters.
WIX- 24070
Baldwin- B5134
Napa- 407
Old May 8, 2014 | 10:19 PM
78fordman's Avatar
78fordman
Do not use the sca charged filters. The sca ended up caught in the oil cooler.
Sent from my leash using IB AutoGroup
Old May 8, 2014 | 10:30 PM
Lynnmcmahan's Avatar
Lynnmcmahan
NAPA 4070 or 4072
WIX- 24070
Baldwin- B5134
Napa- 407
Should be NAPA 4070 or 4072.
Old May 9, 2014 | 08:02 AM
cornstar6207
So, 78fordman, I believe you about using a non charged filter and will do so. But, it begs this question: If the sca will get caught in the oil cooler, wouldn't it get caught in the coolant filter?
Old May 9, 2014 | 08:04 AM
69cj's Avatar
69cj
Actually 4070 or 4069. The 4069 is one inch shorter.
Old May 9, 2014 | 10:34 AM
jmtbiggin's Avatar
jmtbiggin
The oil cooler is commonly called the "primary coolant filter". Your sinister setup is only filtering a fraction of circulating coolant, vs the oil cooler getting most of the flow.
Flaman
Mar 3, 2017 12:43 PM
vectrex
Apr 23, 2012 02:56 PM
Jaaaaaaackman
13
Dec 14, 2009 01:15 AM
live2wheel
Feb 4, 2009 04:40 PM
WOPSUSHI
Mar 1, 2007 08:00 PM
