Coolant flush today
Old May 8, 2014 | 06:23 PM
KIDkiser's Avatar
KIDkiser
Coolant flush today
After working on this all day(just flushed with distilled water)used cat elc.and went for a drive.i noticed my temps went up a little.88 degrees here today and 20 mile trip on the interstate,ect was around 195 ,eot was 198 to 199 that's about 3 to 4 degrees more than before the flush.does these numbers look ok or am I overthinking.
Old May 8, 2014 | 07:50 PM
jswartz84's Avatar
jswartz84
Looks fine to me.
Old May 8, 2014 | 10:11 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Check the cold soak temps between ECT and EOT before you really consider your delta to make sure nothing get into the sending unit. ECT being high isn't typically indicative of oil cooler issues so you're more than likely fine, the split is a-ok.
Old May 9, 2014 | 07:11 AM
KIDkiser's Avatar
KIDkiser
I checked cold soak this morning and ect and eot are about one degree apart with eot being higher.
Old May 9, 2014 | 04:46 PM
klbrown's Avatar
klbrown
After coolant flush and new thermostat my ECT has been 2-4 deg higher.
But it usually ran at about 188-190 and from what I've read, running a bit hotter is better for the engine.
Old May 9, 2014 | 04:50 PM
9228.bobcat's Avatar
9228.bobcat
All is good. It is possible you still have air in the system. But them temps are fine. Next time you run it turn on your heater on high and it will get all the air out if there if there is any.
Old May 9, 2014 | 05:00 PM
sams6.9's Avatar
sams6.9
My 06 6.0 has for years run 200-205 ECT and 215-225 EOT with or without 20K behind it and its been happy
Old May 9, 2014 | 05:22 PM
KIDkiser's Avatar
KIDkiser
Thanks everybody,I guess I can rest a little easier now.lol
parkland
6.4L Power Stroke Diesel
Nov 12, 2012 10:09 PM
davidkstyler
Jul 31, 2012 10:49 PM
69cj
Dec 24, 2011 07:39 PM
06NEWTOME
Feb 6, 2011 08:55 AM
Gental Ben 2
Dec 10, 2010 09:38 PM
