Show off your IDI thread !!
Old Feb 8, 2011 | 03:00 AM
  #361
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by fordman75
It wouldn't be that hard to do a little metal work on the box and move the inner wheel wells and the fender mounting locations.
Are you nuts man? Them factory dually beds are a royal pain to even attach the fiberglass fenders on, there ain't no space to do the kind of work you're suggesting. If anything I'd chop the bed on two somewhere close to the front wall, then stretch the thing by a few inches... or just slide the bed back some and run 3" stacks between it and the cab with some tall but flat toolbox between them for storing chains and straps and maybe some fluids.
Old Feb 8, 2011 | 03:15 AM
  #362
fordman75's Avatar
fordman75
You should know I'm not afraid to cut up metal.
Old Feb 8, 2011 | 03:47 AM
  #363
LCAM-01XA's Avatar
LCAM-01XA
Yeah, but what's the point of moving EVERYTHING fender-related on a factory bed, when it's so much easier to just stretch the bed some? I mean, I'm all for being industrious and all, but what you're suggesting is borderline OCD, lol.
Old Feb 8, 2011 | 03:58 AM
  #364
Diesel_Brad's Avatar
Diesel_Brad
As long as you like removing rivots. I know I had fun removing 62 rivots when I slid the axle forward on my 84 F250 chassis. You won't have that many to mess with though.
And don't forget you'll need to have the driveshaft shortened too.
F-superduty spring hangers are held on with bolts not rivits. It is just a matter of unbolting , drilling new holes 4" forward then bolting back on
Old Feb 8, 2011 | 04:40 AM
  #365
fordman75's Avatar
fordman75
Either way modifying the bed is still cutting and welding! OCD? ME? Never!! You should know by now I like doing things the hard way!
Man I should have known that! I've got a 91 F-Super Duty sitting in my driveway.
What about the crossmember, shock mounts and all the other misc items. Is everything bolted in? If it is that would make things easier.
Old Feb 8, 2011 | 09:10 AM
  #366
Portuga's Avatar
Portuga
When i brought it home
Only good pic i have of how it sits now.
Old Feb 8, 2011 | 09:14 AM
  #367
Austin26372's Avatar
Austin26372
Looks like everything is bolted in, or atleast that's what I want to remember! But now that I think about it, I'd have an interesting time re-locating the shock absorber mounts, as well as running into issues with the front tank.
However, i do like where it sits for towing means. If I have a goose neck in, it doesn't sit so close to the cab.
Old Feb 8, 2011 | 11:58 AM
  #368
fordman75's Avatar
fordman75
When you start moving things around you are going to run into more and more things that are going to have to be modified.
Having the axles set back is better for towing. How is the box length? Is it a good match or is the box short?
Old Feb 8, 2011 | 12:01 PM
  #369
Austin26372
Very true.
The box length seems fine, but I'm not sure what problems I'll have when I put a bumper on it; it hasn't had one on there yet.
Old Feb 8, 2011 | 12:21 PM
  #370
oreocreaming's Avatar
oreocreaming
wanna sell the trailer??
Old Feb 8, 2011 | 12:31 PM
  #371
oreocreaming
Originally Posted by 47ltb
Here's my IDI,
your dad posted some pics of your truck on obn a little while back. you build the steps yourself?
Old Feb 8, 2011 | 12:44 PM
  #372
oreocreaming
theres only 36 rivits to be removed, and can be replaced with bolts. i moved my axle back 2 1/2" and it was easy enough.
Old Feb 8, 2011 | 01:53 PM
  #373
fordman75's Avatar
fordman75
Originally Posted by oreocreaming
theres only 36 rivits to be removed, and cant be replaced with bolts. i moved my axle back 2 1/2" and it was easy enough.
I said mine was 62 rivots. I shortened a supercab chassis to 110" wheelbase so I removed a couple crossmembers and slid a few others forward.
What makes you say they can't be replaced by bolts? Everything on my frame is going to be bolted. I enlarged the holes on all my spring hangars to use 1/2" bolts.
Old Feb 8, 2011 | 02:18 PM
  #374
oreocreaming
didnt mean cant, i ment can. i replaced mine with bolts.
Old Feb 8, 2011 | 02:42 PM
  #375
fordman75's Avatar
fordman75
Man don't confuse me! I'm confused enough the way it is!!!!
