Sponsored by: Real Truck
Gas vs PSD
Old Dec 2, 2010 | 06:03 PM
  #9646
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by 2001400ex
Bill, don't tell me you are off your "it will do 5k rpms for hours,that won't hurt the v10" kick are you? It was a lot of fun
No, of course not.
They will run days on end at peak HP with no problem.
Its when you have poor oil pressure that its a problem...
Old Dec 2, 2010 | 06:07 PM
  #9647
2001400ex's Avatar
2001400ex
Krewat, forgot to mention you stock diesel comment. Every stock diesel from about 2005 on is programmed to defuel long before it will blow up. Look at the rocky mountain test, they floored eack truck the entire 12 miles, did either blow up?
Old Dec 2, 2010 | 08:06 PM
  #9648
exiled's Avatar
exiled
Originally Posted by phillips91
Diesels have less tq drop off from peak tq to peak hp, but once you rev them past peak hp you are losing power much faster than with a gasser. My 5.4 makes peak hp at 4,500 but it has virtually no power loss if I run it to 6,000. If you run a diesel 1,500 rpms past peak hp you are going to do more than just lose a lot of power.
If me and Exiled get to do our tests I had planned on this being one of our test runs. I don't want to video it and post it on here. I want a witness sitting beside of me videoing it so he can verify the load, hill, rpms, gear, speed, etc.
Are you saying hp or tq? The torque curves I've seen of 6.0s of 2200-4200 is rather flat. Aight then that being said flat being w/ in a few hundred. Hp I really don't pay attention to. There's no reason for me to push over 3500 rpms. Your 5.4 don't come close to my 6.0. I've had a few 5.4s 2 3vs 5.4 and my wife still has one. Your 5.4 only makes 310 hp@5k. Its my believe that the rev limter will knock it back down to 4200. But that might be only on the f150s. Its makes somewhere around 350 lbs tq at 4200. 80% of that is 280 lbs. Come on 280 isn't even in the torque curve of the 6.0. So you concluded your manual tranny gives you an edge for 3 seconds. Well that's a conversation of tranny against tranny. Not engines.
Yes I would tell whatever you did with your truck you would want to be told.
Old Dec 2, 2010 | 08:27 PM
  #9649
commtrd's Avatar
commtrd
Let's see...5k rpm at no load for one minute...yep that equals a thrown rod, spun bearing, take your pick. Uh, don't do that...
For a tow rig, a gasser will never perform as well as a diesel. That's why you will never see an over-the-road tractor running a gasoline engine. They can't do the miles or pull the loads. Power curve and torque is not right.
Old Dec 2, 2010 | 08:40 PM
  #9650
bill11012's Avatar
bill11012
What makes you say that?
Back your statment up.
Old Dec 2, 2010 | 08:49 PM
  #9651
commtrd's Avatar
commtrd
In my younger more exuberant days I had the joy of re-building a bored and stroked 327 that I did this precise thing to. But hey, whatever...hopefully you won't send the rod out the side of the block. Anyway, the gassers are OK and the diesels are OK too. Whatever floats your boat. I will say that a 5.4 gasser or a 6.0 diesel will not hold a candle to my 6.7 Scorpion diesel. ;0) 'nuff said...
Old Dec 2, 2010 | 09:45 PM
  #9652
thefordlane's Avatar
thefordlane
It was pretty funny this summer i was at a rodeo and this mini Freightliner with a 6 horse trailer was stuck beside us, and the guy wanted someone to pull him out. So along comes this 2003 F250 V10 hooks up to it, puts her in 4low and jst gives it everything it had, basicall just moanded and groned. So being the nice guy i am i unhook our 2007 F350 powerstroke and hook up to the truck. I put her in 4low built the turbo a bit and then the truck came right out. Not sayin our PSD is a powerhouse, just sayin that low end torque is real nice. Just thoght that i trough this on for some conversation.
Old Dec 2, 2010 | 10:46 PM
  #9653
exiled's Avatar
exiled
Brother there's a difference in the truck can't do the task and the driver can't do the task w/ the truck. Its understandable that he couldn't pull out the truck revving up to 5k. I see him spinning, fighting for traction. He shoulda just used as much ump needed to pull the truck out. His truck was more than enough to pull em out.
Old Dec 2, 2010 | 11:35 PM
  #9654
thefordlane
I know i just wanted to share my story. But it was a rather hard pull, the truck was down hill bout 10 feet and in bot 2 feet deep mud, and i was up on pavement so there was no spinning. Maybe its just my mad driving skills.
Old Dec 3, 2010 | 12:33 AM
  #9655
tgreening's Avatar
tgreening
Just a reminder. A certain someone claimed that a V10 would run 5000rpm for 20 minutes no problem, and then promptly blew one up trying to do it. ( ) I'm assuming this person had enough confidence in the engine to give a go in the first place, but after failure is giving excuses for it's failure. Ok, maintenance history noted and accepted.
If I recall there is still a V10 in the stable. One with a much better maintenance history. Now that preliminary testing is over when is the money run? IOW, back up your statement.
I know what a certain someone else would say. Run your PSD at redline along side me and I"ll do it. Thing is I don't recall anyone saying that the PSD would run at redline all day long, only that it wouldn't need to. The V10 camp though HAS made the claim that the gasser will crank 5k ad infinitum.
Personally I wouldn't run ANYthing at or near it's redline for any period of time what-so-ever. There's no way the ol' reliability / longevity graph doesn't take a serious nose dive under those conditions. There are miles, and then there are hard miles, and overall I believe one engine holds up a bit better.
And so......
Old Dec 3, 2010 | 01:59 AM
  #9656
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by Krewat
And as for my asking that a diesel do the same thing, it's not a deflection. You and CFICO and a few others say the diesel will hold up to a full-load pull for as long as you need to. So do it at red-line, what's the difference?
Afraid it will blow up?
Show me where I said ^ EVER, and I will mail you $20.00 cash. You can't. I said a V10 can't run at redline "all day long" like you, Josh and Bill have repeatedly said. We already blew Bill's up, and it only took 30 seconds or so...Who's next, you or Josh?
Old Dec 3, 2010 | 02:07 AM
  #9657
ChargersFanInCO
And so......
Truth doesn't seem to work around here...However, you nailed them to the wall with that post.
Old Dec 3, 2010 | 06:17 AM
  #9658
RUFFSTUFF's Avatar
RUFFSTUFF
This... is... very... stupid...
Or something like that.
Old Dec 3, 2010 | 07:32 AM
  #9659
rjfetz1's Avatar
rjfetz1
yeah....this thread keeps going & going & going .....Yet i keep coming back to read it or something? not sure what i read yet? maybe mine is bigger than yours?
It's funny its a v10 vs psd yet the almighty 5.4 keeps getting brought up?
Old Dec 3, 2010 | 07:34 AM
  #9660
exiled's Avatar
exiled
You obviously have never driven a diesel with a load as your remarks completely expose you. Egts are a factor of the amount of fuel, not rpms. If you drop a gear and maintain the same speed on a climb, egts go down. So I can be at redline and egts will stay at 600degrees or whatever, but be on a climb at 50 mph and 1,600 rpms and at 1,300 degrees. Then shift down two gears, increase speed and have egts drop to 1,100.
Thanks for exposing your knowledge of the subject.
I haul w/ a diesel and don't see what your saying. My EGT go up when I go up a hill wiether fuel is added or not. When I tested the 3rd gear driving all day I had 3700-4200 rpms 1100-1200 EGTs. I haven't hurd or read anywhere where you lower your EGTs by down shifting. I've always backed off. I can see wot up hill at 4k rpms causeing high EGTs.
This being said how. Long can you hold out at 1300*? If EGTs doest back you off the trans mission temps will. I got 190* in no time when I was empty holding in 3rd. I would hate to see what would happen if loaded.
I'm going to research this. And as it always does this just may end up me trying stuff out on the road. I will be willing to post my findings if yall would like me to.
