Sponsored by: Real Truck
Gas vs PSD
Old Oct 4, 2009 | 10:07 AM
  #2251
Tom's Avatar
Tom
Nah, a 44 Mag is WAY more powerful than a 460.
Blown 460 maybe?
Old Oct 4, 2009 | 10:16 AM
  #2252
Old93junk's Avatar
Old93junk
I like the .45acp round just fine, its a great cartridge............However, the military ran tests not to long ago showing that 9mm simply has the best cyclic reliability of any pistol round (ability to feed, fire, eject, reload) Simply put......Its better to have a functioning 9mm, than a jammed .40 or .45acp. Another reason that most sub-machine guns(MP-5 UZI) are also 9mm..........jams are a bitch, in a combat situation.
Man, this one has gone off topic.................but still fun!
Old Oct 4, 2009 | 10:28 AM
  #2253
scraprat's Avatar
scraprat
Top Answer: 5
Well now that we slipped into the twilight zone....I'll take the Ruger .44 magnum in the back woods for protection myself and the .45 on the street. Nothing wrong with .380 for that sumthin sumthin in case.
Old Oct 4, 2009 | 01:10 PM
  #2254
EXv10's Avatar
EXv10
Originally Posted by KelVarnson
Yeah, don't they use the same slugs?
Kinda like a .40 is a baby 10MM.
The 380 and 9mm are both .355" in diameter but the 380 is shorter and takes a slug w/less grains.
  #2255
Brooksd1991's Avatar
Brooksd1991
I dont care what you say i hear this all the time coming from gas burning 1 ton drivers...My 460 will outpull that powerstroke or cummins anyday. Not likely. First off they make diesels for a reason they have alot more lowend torque to pull heavier loads and to not use much more fuel than driving without a load. They also last longer than most gas engines, but they do cost more to maintain and repair. This is why alot of people drive 3/4 and 1 ton gas trucks. They are alot cheaper to maintain and can pull the load, just not as easily as the powerstrokes. I dont personally care for any of the powerstrokes except the 7.3 im more of a 5.9 cummins guy. Either way they are both international motors, so dont kill me for liking a dodge
Old Oct 4, 2009 | 01:26 PM
  #2256
EXv10's Avatar
EXv10
Originally Posted by Brooksd1991
I dont care what you say i hear this all the time coming from gas burning 1 ton drivers...My 460 will outpull that more of a 5.9 cummins guy. Either way they are both international motors, so dont kill me for liking a dodge
All the big name trucks are fine and proof is that they are still there and that was caused by competition. They are all made by people but it is human nature for people to be a little territorial and luckily not as much as a dog for example. Another example is when people get in fights over who likes a certain baseball team.
Old Oct 4, 2009 | 03:04 PM
  #2257
Lead Head's Avatar
Lead Head
Blown 460 maybe?
.440 Magnum, sounds more like a certain chrysler engine
Old Oct 4, 2009 | 03:17 PM
  #2258
EXv10's Avatar
EXv10
I think Lincoln had a 460 too.
Old Oct 4, 2009 | 09:05 PM
  #2259
alchymist's Avatar
alchymist
"Mifflin Clay"
Then this would be the Cadillac???
Old Oct 4, 2009 | 11:06 PM
  #2260
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Until the 6.4 PSD came out, the 3V V10 (w/ 4.30 gears) beat the PSD in towing tests.
Old Oct 4, 2009 | 11:36 PM
  #2261
Broncoholic1's Avatar
Broncoholic1
Originally Posted by bill11012
Big bore and single action, that is a 460!
I thought so too..
Old Oct 5, 2009 | 12:24 AM
  #2262
95_Dually's Avatar
95_Dually
Are you sure?
Old Oct 5, 2009 | 11:03 AM
  #2263
BigF350's Avatar
BigF350
FTE Emeritus
Originally Posted by 95_Dually
Are you sure?
Ok, how about even against the 6.4:
15% grade with 10,500lb trailer:
7% grade with 10,500lb trailer:
Link to test:
http://www.pickuptrucks.com/html/200...shootout1.html
Old Oct 5, 2009 | 11:29 AM
  #2264
mudmaker's Avatar
mudmaker
That test has come a lot in this thread already! I think it is hard to try and put a pulling test on paper. How many hills do you pull that are only 450 meters long? I would like to see the numbers on a pull like Eisenhower heading out of Denver W on I-70. I would bet that if those same two pickups in that test left Denver at the same time the psd would be sitting at a restraunt in Silverthorne before the V10 even made it through the tunnel.
Old Oct 5, 2009 | 11:45 AM
  #2265
BigF350's Avatar
BigF350
FTE Emeritus
Its hard to put anything on paper.
Its not absolute, but it is indicative.
A lot, but as mentioned, this is a test that is only indicative of performance, not the absolute barometer, its just like a car being quick in a 1/4 mile being quick on the road.
The biggest thing I note there is that the PSD failed to continue accelerating on the 15% grade.
To me that would indicate on a large grade the PSD would hit a proverbial brick wall, while the the V10 with its wider powerband would be able to continue to accelerate.
Well if there are 2 similarly equipped trucks here and someone is willing to arrange a towing test, go for it.
I am certain that the elevation of the pass you are referring to would play into the PSD's cards a little, but I am sure it would be a good test.
I haven't a dog in this fight, but the information posted above seems to indicate that the PSD may be in for a bigger fight than it anticipated.
