Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread,,, Part 2
Old Nov 10, 2016 | 05:32 PM
  #28336
56panelford's Avatar
56panelford
Someone sure turned up the fans here today, very strong winds..
Old Nov 10, 2016 | 07:05 PM
  #28337
Fomoko1's Avatar
Fomoko1
It was another nice and sunny day here, sounds like next week it`ll be cooler and quite windy. Our use of sunscreen are likely done for this year.
What did it cost for your rear window for the pickup John?
Good news on your parts Perry, who is Mikeo0o0o0o, a local wrecker?
Old Nov 10, 2016 | 08:40 PM
  #28338
privateer, eh's Avatar
privateer, eh
Windy here to John, not to bad temperature wise but the wind screwed up the day
Mike is on the 73 to 79 forum and along with number dummy, they can find just about any part there is, who's got it and how many they have.
2 more days and I should be able to put down some paint, cutting it really close on this one, time line says I'm 2 days into the cold when I'm done. Don't think that will happen as tremclad doesn't set up below 5c.
Old Nov 10, 2016 | 08:53 PM
  #28339
Corner Gas's Avatar
Corner Gas
No wind here today but supposed to be windy tomorrow.
Old Nov 10, 2016 | 08:58 PM
  #28340
Fomoko1's Avatar
Fomoko1
Glad to see that FTE was able to come to the rescue once again.
Today was another gong show, a dental appointment to get bone/tooth fragments removed that were embedded in my gum after getting 3 bottom molars pulled last month. After I got home from that ordeal I rescued a friend`s dodge 1 ton that blew a rear axle bearing spitting out one of the axle shafts. He was hauling heavy crushed rock when the axle bearing seized up, the truck ended up sitting on the ground on that side.
When I paint with Tremclad something that's fairly small I put it on or beside a heat lamp which quickly cures the paint. Unfortunately you can't really do that with a truck.
  #28341
56panelford
Can you set up any heat lamps to help with the paint drying if the temps drop too low Perry..
Old Nov 10, 2016 | 09:12 PM
  #28342
privateer, eh
I'm kind of SOL when it comes to painting this thing. I'll have an hour and a half max painting time but I, going to clear coat it at the same time and that should lock it in so the cool down at night shouldn't shrink it to bad. The bad part is hoping it dries and cures enough that I can put the blue tape on the white with out leaving a tape track behind or pulling up the white. I'm laying down the white stripes first as they are easier to fix if anything goes wrong, plus it breaks up the panel so I'm not committed to doing all the black at once.
Old Nov 10, 2016 | 09:16 PM
  #28343
privateer, eh
That would be a real pita, losing a wheel bearing with a load of crush on. I think my dentist left a piece behind also Morris, feel a weird bump in my upper gum
  #28344
56panelford
Sounds like you have it all figured out, hope this weather holds out for another couple months...lol
Old Nov 10, 2016 | 09:21 PM
  #28345
privateer, eh
Good thing I'm only slapping this thing out, I'd be screwed if I was doing a real resto like you John.
Old Nov 10, 2016 | 09:24 PM
  #28346
56panelford
I'd be at a stand still if it wasn't for my shop..
Old Nov 10, 2016 | 09:33 PM
  #28347
privateer, eh
Good thing I live in a slummy neighborhood and can get away with doing this on the street, LOL. Good thing I didn't move into Varsity Heights
Old Nov 10, 2016 | 09:37 PM
  #28348
56panelford
I remember when I was just a kid living in Toronto there was a guy who painted his car out on the street but he should have used a garden hose to wet down the road to control some of the dust...lol All in all it didn't look too bad from a distance, might be how Macco came about...lol
Old Nov 10, 2016 | 09:48 PM
  #28349
privateer, eh
Did the 78 dump truck on the street at xmas time 2011 and did the 75 on the open side of my parking shelter area winter/ spring of 2014, Neighbors are used to seeing me do pretty much anything.
Old Nov 10, 2016 | 09:51 PM
  #28350
56panelford
Well I think it's time I pull the sheets down on the bed Perry...ttyl
