Emergency advice needed
Old Mar 16, 2008 | 07:41 PM
  #151
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Originally Posted by Vinford
Ok its not cross threaded only loose.
I can turn the socket with my fingers but can't get a ratchet on it.
The deep socket I have and its the deepest one I could find goes on to far.
Im going to go back to town and see if I can find a crowsfoot wrench and try that
Ken,
Go to this link. Good info. Ipr Removal PDF
http://powerstrokenation.com/tech/iprcleaning.pdf
Old Mar 16, 2008 | 07:45 PM
  #152
F350-6's Avatar
F350-6
But first I want to get it running so I can drive it to there front door.
What does "GO BIG OIL " mean?
See what I mean about a good attitude? I would have said driven it THROUGH their front door.
Big Oil means a fancier HPOP that can produce more power to run bigger injectors for those who like to modify their truck for lots of horsepower.
I think the owner of the dealership in your fairly small town will end up being on your side. He probably has no idea what his service techs have done.
Scott. The best advice I can give you on your .org problems is to pack up and leave those guys. The grass is greener on this side of the fence anyways.
Old Mar 16, 2008 | 08:08 PM
  #153
sflem849's Avatar
sflem849
I know. They are goofy there...I just like to get them fired up Look at my post count...I spend my time here!
Old Mar 16, 2008 | 09:29 PM
  #154
Vinford's Avatar
Vinford
Originally Posted by PaysonPSD
Ken,
I just came in and saw you posted this link on how to make a tool.
I laughed because I was planning something the same.
I have my socket sitting on my desk with a nut I was going to weld on the end of it so I could use a ordiniary wrench.
So I wasnt to far off on planning to build something.
But I think ill do like your link says .
Old Mar 16, 2008 | 11:32 PM
  #155
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
I was hoping you would see the post. I want so bad for you to drive that truck up to there front door. Git -er-done! I'll be lookin for your next post. Good Luck.
Old Mar 16, 2008 | 11:50 PM
  #156
Vinford's Avatar
Vinford
I added a picture of the dead truck to my gallery.
You have to click on Powerstroke to see it , but its there!
Old Mar 17, 2008 | 12:19 AM
  #157
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Kinda of a coincidence. My truck is white over silver and I used to have a Wilderness 5th Wheel.
You won't be calling it "dead truck" tomorrow. I wish I could be there when you drive up to the dealership.
I'm gonna hit the sack. Be watching for you tomorrow. Later.
Old Mar 17, 2008 | 02:11 PM
  #158
Vinford's Avatar
Vinford
Its running !!!!!!!!!!!!!!! I went for a short drive.
It was hard to start the first couple of times but it seems to be getting better.
But why did it quit to start with?
Low oil in the HPOP?
If so where did that oil go as I did check it once and it was OK.
I dont know how to thank you guys but thanks a bunch.
Im going to drive around for a hour or so (have things to do) and make sure it doesnt quit then Im going to drop around to Ford and see if they want to give me my $300 back.
Old Mar 17, 2008 | 02:40 PM
  #159
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Ken,
Glad to hear you are driving it around. The HPOP has been know to leak and drain down the reserve oil. I will search for some threads concerning that.
If everything is OK it will begin to run better after all the air is out of the high pressure oil system. Can't wait to see your post after you visit the dealer.
Edit : If you find that the HPOP reservoir is draining down post back and we will give you some help with that.
Old Mar 17, 2008 | 03:03 PM
  #160
fxstbchopper's Avatar
fxstbchopper
I have not been online the last several days I am glad to see you got it going.
I would definitely be talking to that dealer and getting your money back.
Old Mar 17, 2008 | 03:06 PM
  #161
GRECO's Avatar
GRECO
Glad to hear you got it running, Ken.
Old Mar 17, 2008 | 03:16 PM
  #162
GregN's Avatar
GregN
I have been following this since post #1 and I am very glad to hear that you got it up and running. The only bad thing that came out of this is knowing that you won't be able to trust those Service Techs again. At least you have us....I am not sure if that is good or bad! ;-)
Old Mar 17, 2008 | 03:18 PM
  #163
zx250's Avatar
zx250
Of the next Riffraff East
Air in the oil system will cause it to be hard to start for a while. A number of reasons could prevent a PSD from starting. Low oil, weak batteries, bad IPR, bad ICP and that is just a few. You have it running, that is a big start. If you ICP was indeed leaking oil, that will have to be replaced. Sounds like the IPR is ok. I assume you have fixed you oil leak. Is you ICP (the easy one to get to) plugged up? How does it run?
Run it a while and park it, check the oil level in that HPOP (hex screw on top side) after it has set over night and see if the level is still within an inch or so. If not, your pump is leaking down and that will cause no starts, but can be repaired. With all the cranking you have done over the past few days, I wouldn't be surprised if your batteries are starting to weaking. Repeated discharges are hard on older batteries.
Old Mar 17, 2008 | 03:47 PM
  #164
bdrummonds's Avatar
bdrummonds
Way to go Ken, keep us informed on how it does the rest of the day.
Old Mar 17, 2008 | 05:34 PM
  #165
Vinford's Avatar
Vinford
Update ...............
The service manager says the pumps going to go soon.
He wanted to know if I would drive it for a week before I got my money back.
He seems to think they are right so i guess we will see as I gave him the week he asked for.
I offered to give him a link to this thread but he didnt want it.
So Ill print it off and keep it for reference.
He says cranking the truck tops up that res everytime?
Then it drains down again.
He agrees it probably needed oil but that was only because some leaked out when they worked on it.
So i guess I will just drive it for a few days and see what happens.
Ive got that new ICP coming.
If the pump is "leaking" down whats the fix for that?
Thanks again for all the help.
