Crewcab Only Thread.
Old Feb 6, 2010 | 11:58 PM
  #871
76f350spercamprspeal's Avatar
See the link in my signature? That say's Enter your truck in Round-2 '61-'79?
Click that, scroll down and post pictures and specifications on your truck in that thread.
Old Feb 7, 2010 | 10:26 PM
  #872
randys79crewcab's Avatar
randys79crewcab
need Crew VIN info
I know there's a guru in here that knows VIN number info. Here's the VIN number, can anyone decipher it for me? Thanks
F25JCAJ2B62
Old Feb 7, 2010 | 10:52 PM
  #873
Sorry Double Post.
  #874
F25JCAJ2B62
F25 = F-250 2 Wheel Drive
J = 460ci V8 4-Barrel Carbureator.
C = Ontario, Canada Assembly Plant.
Here ya go, Randy.
Welcome to FTE!
Your not a new member, But you haven't been around much, so welcome.
Old Feb 8, 2010 | 03:42 PM
  #875
randys79crewcab
Thanks for the info
Old Feb 9, 2010 | 04:57 AM
  #876
Kalve's Avatar
Kalve
Hey I was wondering does anybody know a good wiring harness for these crewcabs? I am adding factory cruise & more lights its a 74 F250.
  #877
Kalve's Avatar
Kalve
an there are some sweet looking crews on here
Old Feb 13, 2010 | 09:08 PM
  #878
forolio's Avatar
forolio
Google VIN number and you will get the breakdown
Old Feb 16, 2010 | 06:35 AM
  #879
73f250400's Avatar
73f250400
trying to save one my self.
Old Feb 17, 2010 | 04:42 PM
  #880
Packard V8's Avatar
Packard V8
headliner trim strip
On the headliner of some mid-70's crew cabs, I've seen a T-shaped plastic chrome strip which grips the rib where the roofs are joined and covers the joint between the two pieces of headliner. Has anyone found a replacement for this NLA trim strip?
thnx, jack vines
Old Feb 18, 2010 | 10:59 PM
  #881
big ed 1977's Avatar
big ed 1977
newbie help?
I have a 1977 f100 2x reg cab longbed. I am wondering if I can take the 8ft bed and cab off the frame and then replace it with a shortbed and a supercab.... anybody seen this done? Is the wheelbase the same? Do I have to lengthen the frame? Any help would be appreciated.
Old Feb 18, 2010 | 11:19 PM
  #882
pickupbuilder's Avatar
pickupbuilder
Super cab conversion
I have done this conversion on a 3/4 ton 4x4. The best approach is to find a pickup that is stock mand get good measurements. The rear axle needs moved back. I think it was around 6 inches. The shape of the frame on a 1/2 ton may make it necessary to lengthen the frame in front of the rear springs. Kind of depends on lift and such with the truck.
Good luck.
Old Feb 18, 2010 | 11:25 PM
  #883
big ed 1977
Thanks.... I am going to do an IRS coversion on it this year... next year will be the super cab conversion.
Old Feb 19, 2010 | 06:11 AM
  #884
ranger429's Avatar
ranger429
So how is this crewcab related?
A regular cab long bed is 133" WB, a supercab shortbed is 138.8". Stretching the frame will be necessary.
Old Feb 19, 2010 | 08:38 AM
  #885
73f250400's Avatar
73f250400
Or take some off the frount of the bed.
