Crewcab Only Thread.
Old Mar 25, 2012 | 05:12 PM
  #1771
Pitcrw6's Avatar
Pitcrw6
Nope. Now they may a made a F350 cc longbed 4x4 in 79 as a 80 model but I dont know about the 80 models.
Old Mar 31, 2012 | 07:49 PM
  #1772
PharmGirl's Avatar
PharmGirl
Originally Posted by AllFordluvr
Hey guys,
I have looked to no avail for a headliner.
ANy ideas of how to do my own?
or materials to use prior to wrapping with fabric?
Need all the help I can get
I am having the same issue, I need the headliner board or a good "fix". Stock interiors has pretty nice fabric and adhesive to finish the job.
Old Mar 31, 2012 | 11:09 PM
  #1773
Pitcrw6's Avatar
Pitcrw6
Buy a piece of formica and use that. flexible enough but still sturdy. No more drooping, works great.
EDIT: BTW welcome to FTE
Old Apr 1, 2012 | 12:33 PM
  #1774
PharmGirl's Avatar
PharmGirl
Thanks! Great idea, I thought about aluminum but I think the formica will be better.
Old Apr 2, 2012 | 03:12 PM
  #1775
gearheadFord's Avatar
gearheadFord
what my buddy did with his, was made it out of like a sheet board, he made a once piece, he got a regular cab taped it up measured it from where it ended to where it should end at the back of the cab, laid it out traced it used his measurements and made a mock up, trimmed it down, covered it and put a light in it, (oh and it makes it way easy if you pull the back window out to do this)
Old Apr 2, 2012 | 05:56 PM
  #1776
punkrockpilot's Avatar
punkrockpilot
ive been wanting to put in a rear slider and i need a headliner so it sounds like i got to do both at the same time. thx for the great ideas.
Old Apr 11, 2012 | 10:01 PM
  #1777
FallenAngel91's Avatar
FallenAngel91
does the mechanical fuel pump on a 76 390 big block have to be primed? I just replaced mine and my truck still refuses to start unless gas is poured directl into the carb. help and advice please?
Old Apr 11, 2012 | 10:45 PM
  #1778
Pitcrw6's Avatar
Pitcrw6
I never had to prime the fuel pump. It was a plug and play thing. Did you disconnect the fuel hose that connects to the carb and try and crank it over to see if you have fuel coming out of the hose? If you dont have fuel coming out then you either have 1) a bad fuel pump or 2) a clogged fuel line or 3) the lever on the fuel pump isnt under the camshaft to move it up and down to pump fuel to the carb.
Old Apr 11, 2012 | 11:36 PM
  #1779
jay54f100's Avatar
jay54f100
Where are all the pics?
Old Apr 16, 2012 | 12:57 PM
  #1780
abyars111's Avatar
abyars111
I'm still looking for a 2wd shortbed crew if anyone sees a nice one around. I don't want a non running project. I've looked at a few and couldn't iron things out before someone else snagged them.
Please let me know if you see any nice crews.
Old Apr 17, 2012 | 11:44 PM
  #1781
gearheadFord
try oldfordcrewcabs.com or even searchtempist.com (it searches all craigslist in specified area) to try and find you one
Old May 1, 2012 | 05:20 PM
  #1782
nehuge's Avatar
nehuge
Saw this pic and thought this was nice...
[img=http://s10.postimage.org/6yn1jp5h1/6862549103_6e141193a9_o.jpg]
Old May 1, 2012 | 11:13 PM
  #1783
fordafire's Avatar
fordafire
+1 and when on craigslist check them all, when you use Search Tempest some people dont write down crew cab in the description. Took me about 6 months but I found the year I wanted about 600 miles away and I was looking for a 73 or 74 High Boy crew. I then flew out and drove it back. If they realize they have a somewhat rare truck it wont be cheap. I have seen quite a few for sale since I bought mine but you might need to travel a bit. My rule is if I really want it I'll go 1000 miles to get it as its just a long days drive back if you fly out. My last ride I bought I went 1000 miles for and drove back 15 hrs the same day. It gets me real close to 50 mpg and saves me about $500.00 to $ 600.00 a month and only cost me $2500.00 so to me it was worth it.
Good luck
Old May 2, 2012 | 06:02 PM
  #1784
gearheadFord
i got lucky i found mine only about 45miles away and spent 2k for the truck, cost me an engine later down the road (cuz the guy didnt tell me the connecting rod to the piston was loose)(broke off and the rod cut my block in half)
Old May 6, 2012 | 10:11 AM
  #1785
punkrockpilot
I found my crew on OFCC and had to fly up and drive it home. I bought it sight unseen and just hoped for the best, lucky for me its been great so far and was able to drive me all the way home without any problems what so ever. The PO was able to deliver it to my inlaws house locally to him. It worked out great that I had the truck too, my inlaws were moving and my wifey wanted all their nice furniture so I hooked up the trailer full of stuff to the truck, crossed my fingers and drove all the way down the CA coast getting 16 MPG. Couldnt be happier or luckier to have found the truck and have the cash in hand to grab it.
