I haven't looked at my DEF tank since I did the delete back in late 2018. Can you cut the tank out and plug the inlet pipe?
yea tank should come out with the normal amount of hassle...ive seen guys run the air chuck connect to the def filler spot for their air on board setup.
Advice of the big local diesel shop is to fill it completely up with DEF before the procedure and leave it sealed up. Reason being is that a full tank will hold less air and therefore will be less likely to crystalize over time. So what I did was I filled my DEF tank completely with the "Premium" DEF a few days before the tune so that the good non-crystalizing formula would be sent throughout the lines and injector. Hopefully in the future IF I have no choice but to return the truck to stock the DEF system will be perfectly functional.
I'm leaning towards removing the tank and draining it. If that turns into a huge hassle, then I'll fill it and forget it.
I disagree with this advice, there will be evaporation and there will be crystallization, just how much and when is the question. If you really want to preserve the system properly, drain and flush with water the tank, lines and injector and then blow air through the lines and injector and make sure the tank is dry.
I guess I need to crawl under my truck and see if my DEF tank is still there.
I don't know why you would want to preserve the DEF system if the emissions are deleted.
Because of the last line of WXboys post.
There may come a time when he needs it to be functioning like: resale restrictions, he moves to an area where emissions are required, etc.
Yeah the way the pot has been stirred in this country, I personally think it is foolish to get rid of all your emissions equipment, as any state legislature could decide to bring back testing at any time. I'm trying to play it smart by keeping my EGR cooler, connections, "space ship" from under the truck, DEF system, etc. for the "just in case" scenario.
Shop owner who gave me the DEF tank advice said that not long ago he had a customer who needed to return to stock after 5 years. The DEF system all functioned correctly when they reflashed it to stock. If it were an easy job to remove the tank, flush it, clean the lines, etc. I probably would....but we all know that it's actually a b*tch to do that on these trucks. So I filled mine up, and then both ends of the system are sealed (end of the line is wrapped in plastic and sealed with tape) so hopefully it'll be fine.
The DPF is the most expensive part of the emissions crap by far. If someone has permanently discarded their DPF after the delete might as well go all the way and get rid the EGR piping and DEF tank.
Go big or go home!
Go big or go home!
its one of those "i'll get around to it when i get around to it" and suddenly it's been a year and that ish is still attached to the truck lol
They still do emissions checks across the road from my house where the county line is. It is why I got rid of my deleted truck. With ol fat pants as governor, I would not put it past fatty to pass a law making every county do emissions tests. IOW if I deleted my truck, I want the option to roll it back and avoid $45K in fines and the loss of the truck if it can't be put back.
So I was using a Scan Gauge II hooked up to the OBD port to monitor soot load, regen status (on/off), etc. Something interesting that I've noticed is that since going on the weight loss program, the soot load value continue to slowly increase. It's going up more slowly than it did before, but it still reads a value and it's increasing daily. Makes me wonder where that info comes from? Is there a sensor onboard that may be still installed and still reporting to the PCM? Today it's up to 94% load. I wonder if it'll try to kick on a regen soon? Or will that number just continue to climb forever without a regen?
Did you remove your EGR? Wondering if the scan gauge is measuring that? 5 years after my weight loss on my truck I haven't noticed any issues.
Maybe accelerating quickly will blow out any soot?
Okay, 2021 F350 6.7L DRW 8 FT BED 33k on it. Truck sits in my drive with a big truck camper on it. I use it to haul a 5500lb boat every week in season to the local ramp and back and 1600 mile trip to the Keys for 5 - 6 months every winter. After all these pages of reading I have one question. Should I put the truck on a weight loss program?
