E99: Yet Another S300 SX-E Thread
Old Aug 23, 2021 | 03:28 PM
  #466
PriusLover's Avatar
PriusLover
I looked back through your thread to see why you have so little clearance for your up pipes but did not find anything.
When I installed the up pipes I tried mounting them symmetrical on the manifold ball flange, but doing so resulted in contact in the above two areas.
Short of removing the up pipes and having them bent—which isn't gonna happen before the transmission comes out—there is no way to have the up pipe sit on the flange symmetrically without the pipes hitting the engine.
Based on the wear pattern on the manifold ball flange, it looks like they weren't mounted symetrically from the factory. The whole point of a ball n socket joint is to allow some variability WRT mating angle. The problem here is the ball flange is extremely pitted, and the clamps do not provide uniform clamping force due to premature deformation and lack of chamfer on the contacting edge.
New manifolds would likely fit the problem but, aside from being expensive, that potentially means new leaks where they mate to the engine. Smoothing the interior of the up-pipe flange might help, but there are limits on how thoroughly I can do this without removing the pipes.
Only thing I can think of for now is stronger bolts and a copper crush ring or pre-existing exhaust gasket that can be made to fit.
Old Aug 23, 2021 | 04:26 PM
  #467
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Maybe you could modify something like one of these to fit the bill for now
https://www.summitracing.com/search/...-donut-gaskets
Old Aug 23, 2021 | 05:38 PM
  #468
PriusLover's Avatar
PriusLover
Got new partially threaded 10.9 bolts and found a gasket at the auto parts store that seems to fit well.
The gasket ID is ~2 inches (larger than the ID of the exhaust manifold ball flange) and has a metal center. This should mean that, if the gasket suffered a catastrophic failure, it should blow out vs being sent to the turbo.
Torqued both bolts to 30 ft-lb and did the soap water test. Seals completely! I put on the brakes and revved it in drive a little, still no bubbles. Have to take it for a test drive to know for sure if it'll hold under WOT... currently refreshing the overload springs so u-bolts are off. Will have it back together on Wednesday, so will find out then.
Old Aug 23, 2021 | 10:13 PM
  #469
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Nice work. The bracket/collar on the up-pipe looks better now too.
Hopefully this fix action will hold together for you long term and you can start enjoying the truck and what it enables you to do and experience.
Old Aug 24, 2021 | 04:00 AM
  #470
FordTruckNoob's Avatar
FordTruckNoob
Sorry. I had not considered your clearance issue might be in the lateral direction. It is odd that your up pipes come that close to the engine/bellhousing.
In any case, it looks like you got your issue figured out so well done.
Old Aug 24, 2021 | 06:44 AM
  #471
KubotaOrange76
Awesome job, ID like to hear if there is a noticeable improvement in drivability too.
Old Aug 26, 2021 | 12:28 AM
  #472
PriusLover's Avatar
PriusLover
Dug out an old tablet and configured Torque Pro gauges (including a transmission fluid temp finally). Will supplement this with an Isspro EGT gauge above the steering column, and will check fuel pressure with liquid filled gauge in the engine bay.
Old Aug 26, 2021 | 07:28 AM
  #473
FordTruckNoob
For TCSlip, be sure to read TCSlipAct and not TCSlipDes. Consider adding EBP.
Old Aug 26, 2021 | 08:32 AM
  #474
Sous's Avatar
Sous
FTE Emeritus
In addition to what Leonard mentioned, consider adding MAT instead of or in addition to IAT.
Below you can see a "gauge overlay" I created (thanks for the help Leonard) to show the performance and PID's when towing with the 363 SXE for the first time. I attempted to bunch the like PID's together in order to keep comparing them easier on the eyes and attention span.
The best part of about these virtual/digital gauges is that they are customizable to your liking. So, if you prefer to have IAT only, that is 100% up to you and there is nothing wrong with that. For my use, I preferred to see the delta between IAT and MAT, just like between EBP and MAP.
Just a couple of thoughts to ponder on when your mind goes to wandering.
Old Aug 28, 2021 | 02:52 AM
  #475
PriusLover's Avatar
PriusLover
Using Tugly's stuff in Torque Pro. The PID for TC Slip is 2211b8... Assuming this is the right one? His Turbo Pressure Delta gauge is supposed to show difference between EBP and boost I think. Is this sufficient?
Got the Isspro pyrometer installed and working. Opted for steering column placement to keep the gauge in the same eyeline as the dash. Works great and doesn't obscure important info.
Here's a close up of the tablet. Shows the max recorded values from a WOT test drive this evening in a PHP 80HP performance tune:
I'm starting to wonder if the Hydra prevents the PCM from "seeing" more than 25 PSI boost? Can't seem to get above that number. ICP hit ~3200 (bodes well for the used L99 HPOP). EGT maxed just under 1200° IIRC. "Turbo pressure delta" hit 13PSI. I'm sure y'all will be able to decipher this info better than I.
Finally got the Dorman coolant bottle in. Works great with no leaks and makes the engine bay look less decrepit. The old bottle is disgusting with some kind of sludge at the bottom (fluid is fine, though).
Still need to check fuel PSI but will likely do so after the trip this weekend. Will also hook an analog gauge up to the y pipe and compare to the sensor reading.
Old Aug 28, 2021 | 08:07 AM
  #476
RacinJasonWV's Avatar
RacinJasonWV
MAP sensor will only allow a max reading of 25psi boost. This is the limit of the sensor. It will require an aftermarket gauge to read actual boost beyond this point.
This plays into the max delta you are seeing as well. Once the boost reading is maxed out then your delta values are no longer true. It will still be beneficial during sustained boost towing to see how good the boost:EBP ratio is.
Good to see you enjoying the truck a bit.
Old Aug 28, 2021 | 08:12 AM
  #477
FordTruckNoob
Oh. Sorry I can't help with Torque Pro since I have never messed with it. I'll page @Tugly for you. He can verify.
Boost should be the difference between MAP and BARO, not MAP and EBP. The difference between MAP and EBP is an odd way of figuring out Drive:Boost ratio.
Do you not have a separate boost gauge? If you are getting more than 24psi boost and you are not getting an SES light, then the tune is probably suppressing the true reading from the MAP Sensor. I forget what the FSD of the MAP Sensor is at the moment but I think it is not far from 25psi.
Old Aug 28, 2021 | 08:59 AM
  #478
RacinJasonWV
The way I read this she is
- using a calculated channel (MAP-atmospheric) for “Boost” reading.
- using EBP - “boost” = the delta reading, which is correct for reading drive:EBP ratios (edit) seeing a quick reference of pressure differential.
24 or 25 is the PCM “boost” limit. It can’t read more than that. PHP tunes will prevent the SES for overboost and the reading will top out (read mine through Edge CTS). I never used the PID for boost until I was watching for my boost:EBP condition recently. The CTS1 doesn’t have calculated channels (not that I know of anyhow) so I just compare the readings.
Old Aug 29, 2021 | 06:20 AM
  #479
Tugly's Avatar
Tugly
The turbo pressure differential is good for towing and for a few other things. Too much differential while towing (not a WOT test), might indicate an issue with your compressor wheel. TDP for me shows my backpressure while engine braking, and it shows what's going on the the EBPV while driving when the weather is really cold. "Why is the truck so slug... oh. EBPV active."
Your ICP 3200 might be good... or not. You need to log the data to see how that 3200 PSI was reached.
Your IPR maxed out, but your scale tops at 50%. That scale needs to be set to 100 when scrutinizing your WOT performance. I set mine at 50% because I know my truck. I suspect you will see a Stinky Spike, but that needs to be verified.
Your boost is covering the Ford logo... bad FTE-er. You will hear a knock at the door soon, be calm... it's just the therapy team assigned to you.
Old Aug 29, 2021 | 10:33 AM
  #480
Sous's Avatar
Sous
FTE Emeritus
It has been almost a week now, how are the gaskets holding up? Have you had a chance to drive the truck much in order to put them to the test or is it in waiting for the Wyse 4R100?
I have saved the part number and images you noted for us for future reference for someone facing a similar issue in the future. Thank you for taking the time to document your steps and parts utilized.
