E99: Yet Another S300 SX-E Thread
Old Sep 5, 2021 | 01:24 PM
  #496
PriusLover's Avatar
PriusLover
Well, not sure what to say. The thing that throws me for a loop is the idle sounding different here vs just when the truck is warmed up. Never had a vehicle that did that.
Old Sep 5, 2021 | 02:32 PM
  #497
BWST's Avatar
BWST
Got Data?
I can hear it. The video appears to start with the noise, then it gets somewhat quiet then comes back again. It seems a little more pronounced at the beginning and at the end of the video. Could you capture this idle sound under the truck instead - might stand out a bit more for us when it occurs.
As far as isolating it - would looking at PerDels help? You might need a known good injector to swap out an injector suspect. I'm basing this on the adventures Tugly had with his rig.
Have you tried different CPS styles to see what your truck prefers?
Old Sep 14, 2021 | 01:16 AM
  #498
PriusLover's Avatar
PriusLover
I have swapped between a new Motorcraft CPS and a black one that I assume is the original version. Didn't seem to yield any change. I'll see about capturing an idle sound... is tricky as I live directly off a busy street.
Perdels would be incredibly useful to see but I've just confirmed that my PCM doesn't expose those PIDs to Forscan Lite, even after the truck has been warmed up. The CCT comes back clean the last several times I've run it.
Seems the only way forward is to remove the valve covers and start unplugging injectors.
Old Sep 14, 2021 | 06:52 AM
  #499
FordTruckNoob's Avatar
FordTruckNoob
Good reason to go on another camping trip. What about pointing a PVC pipe at various parts of the engine and holding the other end to your ear/microphone to isolate where the noise is coming from?
Old Sep 14, 2021 | 07:36 PM
  #500
PriusLover's Avatar
PriusLover
Already been looking a coast get away. Just a matter of finding car-camp legal places (surprisingly not straight forward!).
Old Sep 15, 2021 | 06:55 AM
  #501
FordTruckNoob
I spent 4 years in Glasgow, Scotland. That does not faze me one bit.
Old Sep 15, 2021 | 04:09 PM
  #502
PriusLover's Avatar
PriusLover
Old Sep 17, 2021 | 04:43 AM
  #503
FordTruckNoob
I've passed through Motherwell. It's a *****e(pronounced shyte)hole full of wee *****es (i.e. teen parents raising future teen parents).
Old Sep 22, 2021 | 01:57 AM
  #504
PriusLover's Avatar
PriusLover
Was in the country and had a change to push the go pedal to the floor and see what happens. I used a PHP 65HP Performance tune. Was impromptu so didn't record all the PIDs, but the important ones are here:
ICP was ~ 2650 PSI average. Curiously the IPR slowly increased from 50 to 60%... does this signify tired HPOP or injectors? Evidently boost sensor tops at 25... need to get an analog gauge installed. EGT was around 1100-1150 by the end.
Does pedal position top out at 65 percent? Pretty sure it was to the floor. The pulsewidth sawtooth pattern is the injectors being indecisive about whether they want to start firing after coasting. Any idea why this is happening?
Wouldn't be proper post in this thread without another video of the knocking. Seems to be much worse after the truck has been driven hard. Really curious what would cause an injector to make a noise like this. I ran a CCT while it was idling with intermittent knocking. No errors detected.
Old Sep 22, 2021 | 03:34 AM
  #505
FinnishStroker's Avatar
FinnishStroker
ForScan APP PID maxes around 74%.
That PW sawtooth is probably in the tuning.
I hear the knock on that one,you surely have done the "coasting test"?
You have the DIY 4 corner feed right, monitoring fuel pressure?
Old Sep 22, 2021 | 07:13 AM
  #506
SkySkiJason's Avatar
SkySkiJason
In my experience, a tired HPOP struggles to make high ICP vs tired injectors that make good ICP, but it falls off and DC increases with extended WOT.
The noise you are hearing can totally be related to injector wear. That does not mean catastrophic failure is eminent. Your truck could run like that for a looooong time.
Old Sep 22, 2021 | 05:24 PM
  #507
PriusLover's Avatar
PriusLover
@FinnishStroker Knocking never occurs while coasting. Only when injectors are firing and warmed up. Yes I've the four line feed, new fuel pump, hutch mods. No I haven't checked fuel pressure yet because I'm really lazy ; )
@SkySkiJason I guess that bodes well for the health of the used HPOP I put in.
Old Sep 23, 2021 | 12:28 AM
  #508
FinnishStroker
No knock while coasting points to the injectors.
Also something mechanical would be louder in cold engine and softens when warmed up,i think.
I thought that you had done injectors allready,but you have still stockers,right?
Old Sep 23, 2021 | 02:42 AM
  #509
PriusLover's Avatar
PriusLover
Yup 1-7 are all likely the original AB injectors. #8 is an AB Alliant... put in to try and remedy the knock I imagine.
Old Sep 23, 2021 | 06:57 AM
  #510
SkySkiJason
People (foolishly?) change #8 (and #3) all the time because they commonly fail CCT...
