FTN's T4/SXE Build/Conversion Thread
Old Mar 20, 2021 | 07:49 AM
  #841
SkySkiJason's Avatar
SkySkiJason
Did you forget to tell us you used an impact wrench on compressor wheel????
Just kidding...
Old Mar 20, 2021 | 08:00 AM
  #842
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by KubotaOrange76
It looks like a lack of greta tears to me
in all seriousness i sent to two of my engineering buddies for their opinion. Alot going on there.
maybe post here?https://www.eng-tips.com/threadminder.cfm?pid=330
ill post it on irate4x4 too if you want, some pretty smart guys on there. I dont have much to offer, it looks like slow break
Just kidding...
Yes. This one:
Old Mar 20, 2021 | 08:16 AM
  #843
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds plausable? @FordTruckNoob
https://irate4x4.com/chit-chat/35116...ink#post351205
Old Mar 20, 2021 | 08:21 AM
  #844
FordTruckNoob
Yes, very much so. My thoughts have been progressing down the same path.
Old Mar 20, 2021 | 05:02 PM
  #845
KubotaOrange76
this sounds promising from that thread
"Obviously signs of fatigue cracking, which looks to have initiated at about 7 o'clock in the picture on the outside of the shaft. The progression and origin is consistent with primarily bending load, as is the final failure plane (perpendicular to shaft).
What I'm less sure of is what caused that loading - imbalance is the most likely source of bending load to me, but the only cyclic change is in magnitude and that only with change in compressor shaft speed, which means relatively few cycles of fairly low magnitude - for that to cause failure it would probably have to be significant imbalance and/or significantly higher than design speed. That being said, I am not sure what compressor surging looks like in term of shaft load - I would expect vibration and torsional loading, but I'm not sure if you get enough pressure imbalance across the wheel to cause significant bending load, and with rapid enough change to cause cyclic loading. Also, I would be surprised to see enough load to cause shaft fatigue without also having visible compressor blade damage."
Last edited by Y2KW57; Mar 21, 2021 at 01:46 AM. Reason: Formatting change to denote quote from another website. Text color change to improve readability of quote.
Old Mar 20, 2021 | 05:11 PM
  #846
FordTruckNoob
Yeah I saw that post. I’d say he’s on the money for not having knowledge of the other runs outside of what was shown in the video. I’m hoping the BOV will take away a major contributor to turbo failure.
I see that forum is populated with a good amount of jokesters too.
Old Mar 21, 2021 | 01:41 AM
  #847
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That is the cutting culture of PIrate4x4.
Another human characteristic to consider is the tendency to make a wise crack, in the absence of anything wise to say.
Old Mar 21, 2021 | 07:53 AM
  #848
RacinJasonWV's Avatar
RacinJasonWV
Wise words.
Old Mar 21, 2021 | 08:54 AM
  #849
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
We are seeing that sort of thing more here recently as well. The problem with paradise is that everyone wants to be there, even the ones that don't really, truly want to be. They want to make it their own version of paradise, which is not what it has grown and become.
Live and let live...
Leonard, good on you for taking macro images. Not only does it give us something to ponder and discuss, but you may the opportunity to share them with Borg Warner one day. There are a couple of Borg Warner plants somewhat near me, it would be nice if I could walk in and exchange it for you like at Walmart.
Old Mar 21, 2021 | 04:00 PM
  #850
FordTruckNoob
I went data logging today. I forgot to hit Record on the video camera until the very last run.
Be prepared for a very strange video with only gauges with bouncing needles and/or squiggly lines on the screen for a long while, possibly set to easy listening jazz music.
Old Mar 21, 2021 | 05:22 PM
  #851
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I went data logging today. I forgot to hit Record on the video camera until the very last run..
No worries. A nearby motorist with a dash cam happened to catch you driving by. It's already on YouTube.
It would be interesting to see the data logging on that run though.
Old Mar 21, 2021 | 06:01 PM
  #852
SkySkiJason
Looks HOT!
Old Mar 21, 2021 | 07:08 PM
  #853
RacinJasonWV
2 jokes today. You’re on a roll!
Old Mar 22, 2021 | 07:02 AM
  #854
FordTruckNoob
I knew I smelled something.
Looks HOT!
Paris?!
Old Mar 23, 2021 | 05:21 AM
  #855
FordTruckNoob
Okay I well and truly F'd up. Even the screen cap of the Turbonator readouts got screwed up. I'm going to have to log again.
