Khan's 95 Build thread
Old Feb 4, 2021 | 10:55 PM
  #241
farmert's Avatar
farmert
Might take a look at fuse #6 (15 amp) in the in cabin fuse panel, as it protects the fuel selector, which in turn effects the fuel gauge. It also protects the air conditioner clutch.
Old Feb 4, 2021 | 11:09 PM
  #242
Hit Man X's Avatar
Hit Man X
Been there. $450 later and reeking of Diesel my tanks work. Before I could use front only or flip switch would draw from the front and return to rear.
I think I put some info in my build thread about it. It was easier to do than Comp 910s.
Old Feb 5, 2021 | 06:10 AM
  #243
JayTheCPA's Avatar
JayTheCPA
That is exactly the reason why I have not touched my selector valve since I bought the truck.
Am going to move the system over to the 38 rear mod, completely eliminate the switching valve, and use the midship as a holding / transfer tank. Might take the first steps in this direction shortly as I may have a reason to drop the midship tank.
In doing the quick mental math, the 38 gallon rear tank mod should cost less than replacement of a selector valve with a bonus of improving reliability of the truck
Old Feb 5, 2021 | 06:30 AM
  #244
Edgethis's Avatar
Edgethis
Man you guys get all the fun projects. 910s, super selector valves...Im over here just trying not to freeze or break anything
I did find a T6 turbo mount laying around if you wanted to go that way instead of a measly T4.
Old Feb 5, 2021 | 07:46 AM
  #245
BBslider001's Avatar
BBslider001
Exaaaaaactly. I am not sure why more don't go this route. I always hated the two tank thing.
Old Feb 5, 2021 | 10:26 AM
  #246
JayTheCPA's Avatar
JayTheCPA
I do not mind dual tanks and actually like the theory of it. But am reading too many reports of that expensive switching valve failing which has me focusing on eliminating it. At one point my OBS had three tanks as one of the POs installed a transfer tank in the bed, and then another PO yanked the tank but left all of the wiring and hoses.
Would actually like a OE dual tank system in the SD, but really have not needed it with the stock 38 gallon tank which holds ~40 when accounting for the filler neck. I did look into larger tanks, but the price tags were not appealing. Thought about a transfer tank in the bed, but I actually use all of the bed.
Originally Posted by Edgethis
Man you guys get all the fun projects....Im over here just trying not to freeze...
Making nice with the job handlers is always a good thing as they have a big influence on where the next PCS lands
Old Feb 5, 2021 | 10:35 AM
  #247
TheFecalFanatic's Avatar
TheFecalFanatic
I have no issue keeping the selector valve if that ends up being the issue.
The original one lasted 244k miles and 26 years, I'm sure everything will be electric by the time the replacement fails.
If it fails before that the front tank is getting scrapped and the rear tank will be the only tank. Could always plumb in a sweet air compressor tank in the front spot.
Old Feb 6, 2021 | 08:28 AM
  #248
TheFecalFanatic
Got the truck home last night. Adding 5 gallons of diesel to the rear tank stopped the pump from pulling air, so this confirms that my selector is stuck on the rear tank.
I pulled fuse #6 and it was not blown, so a new selector valve is on its way....
Old Feb 6, 2021 | 09:40 AM
  #249
BBslider001
Where did you find one? I thought they were scarce anymore.
Old Feb 6, 2021 | 10:32 AM
  #250
TheFecalFanatic
Riff Raff sells them, and I found the actual Ford one on Amazon too. I'm sure there are other places that probably have them.
I noticed Amazon has a bunch of generic ones for 80 dollars, though I wouldn't want to try it...
Old Feb 6, 2021 | 10:45 AM
  #251
BBslider001
Smart man...10 char
Old Feb 6, 2021 | 10:49 AM
  #252
TheFecalFanatic
Smart man...10 char
Didnt want to write out 10 paragraphs huh?
Old Feb 6, 2021 | 10:51 AM
  #253
BBslider001
haha....not today....not ever
Old Feb 6, 2021 | 07:00 PM
  #254
z31freakify's Avatar
z31freakify
Coming along great man. I'm in the two tank fan club as well, it was only a few years back you couldn't buy, the selector valve, DEGAS bottle, Windshield fluid bottle, door handles, and other little nick knacks for these trucks thankfully the aftermarket and some OEM parts started to become available.
Old Feb 22, 2021 | 08:51 AM
  #255
TheFecalFanatic
Finally installed the new selector valve. 450 dollars later from Riff Raff and it was on my door step. I opted to wait until the weekend barring any issues that pop up. It's always that 20 minute install that turns into 4 hours of swearing. 🤬
Both bolts stripped trying to take it out, the captured nuts broke loose from the plastic bracket. Ended up needing to Sawzall the top bolt off.
What was interesting was when I was disconnecting lines, the front tank source port was leaking through the rear tank source port. Not sure if that was because the unit was bad or it got stuck in-between changing tanks. Must have configured the access control list wrong.
