Oh man. The dually is obnoxious...dogdick red. Manual. Straight hilarious. Mister Edgethis' truck makes mine look like a Geo Metro.
Theres a bunch if times when I back in a spot and I'm still half way into the lane, I just say screw it and park. What can you do. I generally try to park at the back of lots where I can pull through.
I can't wait till I get the new wheels and tires Kahn convinced me to get installed
Hey Khan, getting ready to order some paint and I was wondering if you could tell me what your paint code/ color is for your truck? I like it and might see if they can use the paint code to mix up a batch. Looks like there were a few different whites they painted with. Also, curious if you have to JB weld a boss on the fuel tanks and run a line between the two or did just putting the one on the filler neck work for the fuel filler trick? Sorry for all the questions.
Just double checked my paint code, it is YZ, which is Oxford White.
The tank mod I JB welded 3/4" hose barbs on both the fill neck and the tank. They work awesome and it's definitely worth while since your truck is stripped down.
No worries on the questions.
Thank you! I will for sure be doing this. Looks like it's a huge benefit and not huge hassle.
While under the influence I ordered CNC Fabrications Stage 1 Valve springs and Manton .120 thick 3/8's push rods. Thanks @Hit Man X for constantly putting it in my head! now to get/borrow tools for measuring valve spec to shim these out to 1.800 @ 119 lbs. I'm debating shimming out to 1.790 or so to get about 124 lbs. on the springs. anyone more knowledgeable on valve springs?
Can’t wait to hear how the install goes and the difference after! I am definitely not more knowledgeable about valve springs, but from what I have read, as long as you don’t shim to the point where you’re getting spring bind, you’ll be good
Ya, I'm pretty knowledgeable on springs. 5 seat lbs isn't going to make much difference at all. When I did mine originally I tried to get about 120. The ones I have now are a little more with the different cam. Coil bind won't be an issue where you are putting them.
I'll stick with the install height of 1.800" at 119 lbs then and call it a day.
