Khan's 95 Build thread
Old Aug 30, 2020 | 08:49 PM
  #106
oldbird1965's Avatar
oldbird1965
Your right, the FUN never ends!
Old Sep 4, 2020 | 08:13 PM
  #107
TheFecalFanatic's Avatar
TheFecalFanatic
Pulled the rear tank. Going to tackle the sending unit stuff and fill neck tomorrow. Also need to cut the welds on my bumper brackets..
Old Sep 5, 2020 | 09:38 AM
  #108
BBslider001's Avatar
BBslider001
That looks like ZERO fun.
Old Sep 5, 2020 | 10:01 AM
  #109
TheFecalFanatic
Fixing hacks never are, but I'm hoping it goes smooth. Today is basically not fun in general. Cutting that thing out of the fill tube, cutting welds and doing tank work.
Old Sep 5, 2020 | 12:05 PM
  #110
BBslider001
I hear you. At least the results are very worth it.
Old Oct 10, 2020 | 09:45 AM
  #111
TheFecalFanatic
Lame update. Added a 3/4" PEX ball valve to my supply line to cut off radiant heat in the cab. With it being a little cooler I can feel the heat coming through the vents. Ironically this truck had valves on the supply and return lines but they were seized up and hard to open.
Old Oct 10, 2020 | 09:55 AM
  #112
z31freakify's Avatar
z31freakify
Where did you find the new washer fluid bottle?
Old Oct 10, 2020 | 09:59 AM
  #113
TheFecalFanatic
Pretty sure I ordered it from CP Addict. If I recall correctly it was roughly 40 dollars without the pump. I reused my pump, but I think there is an option for a pump for an extra 30 dollars or so.
Old Oct 10, 2020 | 10:49 AM
  #114
z31freakify
Sweet. The one on my mule is dry rotted not leaking but great to know they make one.
I remember the time no one offered new coolant bottles what a mess that was lol.
Old Oct 10, 2020 | 01:16 PM
  #115
TheFecalFanatic
Mine wasn't leaking but I figured it wasn't a bad idea to replace it since I was changing to the degas style cooling system. Its a Motorcraft piece so I expect it to last another 20 years lol
Old Oct 10, 2020 | 03:06 PM
  #116
z31freakify
A few years back not even Motorcraft was available. I had to adapt an E series coolant bottle because only FoMoCo made the OBS coolant bottle and they were discontinued. Fun times.
Old Oct 10, 2020 | 03:10 PM
  #117
TheFecalFanatic
I had no idea it was that bad. Luckily at this time they're still being produced, I'm assuming the market was big enough for Motorcraft to bring it back. Now's your chance to get back to stock
Old Oct 16, 2020 | 09:37 PM
  #118
TheFecalFanatic
Got some work done awhile back, life has gotten in the way of trying to install this tank. Will hopefully install tomorrow. After this is up I'll hang the spare under it and list the parts I used/ snap pics for everyone that's curious.
Used a 90 degree fitting and bent to match supply line. Then bent another 90 degree off that and set at 12" long. This barely fits and is at the tank wall.
Sending unit installed.
Old Oct 16, 2020 | 10:22 PM
  #119
BBslider001
Looks great bud! Nice work.
Old Oct 16, 2020 | 11:03 PM
  #120
TheFecalFanatic
I'll keep at my truck if you keep at yours! That dually is looking really nice by the way. Sometimes I wish I had an SD truck as it seems most of my "mods" are just updating to the SD stuff.
Has Ike found a home yet or do you still have him?
