2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2020-2022 Super Duty FORScan Spreadsheet
  #286
Old 07-03-2020, 03:54 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Originally Posted by Riptide31
This. I would really like to have my DTE read correctly. I have it set through forscan to the 60 gal tank. There must be two spots to change it, hopefully forscan will map it out soon.
check the 2020 ForScan thread
  #287
Old 07-03-2020, 03:59 PM
Rich53's Avatar
Rich53
Rich53 is offline
This is the posting in the 2020 spreadsheet thread, thanks to ZooDad for relentlessly pursuing the solution to this issue, this was the magic bullet on my 2020 truck, now I am seeing 900 miles range with around the town driving.
Originally Posted by ZooDad View Post
Great news for all the larger than stock fuel tank people.
I found an odd entry in the IPC where the fuel level is captured from either the IPC or PCM. My 2020 and three others are all set to PCM. I had the change to IPC tested and voila the DTE rose to the calculated level it should be.
The change has been made in the spreadsheet.
IPC 720-09-01 xx*x xxxx xxxx
If your current value is 4 change to 0
If your current value is 6 change to 2
The difference is if you have Trailer TPMS (TTPMS) enabled
ZooDad
  #288
Old 07-03-2020, 06:34 PM
Parapilot's Avatar
Parapilot
Parapilot is offline
Without making the recent update to the IPc
Originally Posted by Sharkhunt
Super stoked! I am curious to see what those with stock tire heights and reasonable driving habits show for DTE. Let’s see those 999s, will we see 999+ on this generation? Thanks ZooDad!
Once I’m home I’ll be curious to see if there is any further change and my ipc plain English is reading it at70gal
  #289
Old 07-03-2020, 07:37 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
what value do you have in the IPC for the tank size ?
Nice to see 1000+ DTE
ZooDad
  #290
Old 07-03-2020, 07:49 PM
Parapilot's Avatar
Parapilot
ZooDad
the value for 70 gal I believe a5a but I did what the spread sheet had
about to Check / possibly change the other ipc value
  #291
Old 07-03-2020, 08:05 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
gotcha
thanks
  #292
Old 07-03-2020, 08:15 PM
Parapilot's Avatar
Parapilot
720-09-01 updated!
gotcha
thanks
Was just at 780 or so and with the update it’s accurate with my avg being 21.8 mpg
  #293
Old 07-03-2020, 08:23 PM
Parapilot's Avatar
Parapilot
Trip screen
gotcha
thanks
has anyone looked in to changing the trip screens from having dte to how many gal used?
  #294
Old 07-04-2020, 09:55 AM
Riptide31's Avatar
Riptide31
Riptide31 is offline
ZooDad
Thanks to you all! I really appreciate it
  #295
Old 07-05-2020, 11:01 AM
Ron Hill's Avatar
Ron Hill
Ron Hill is offline
Thanks ZooDad for the info on IPC change, Currently at half tank showing 327 DTE, alert the change DTE went up to 478! Waiting on a full tank now but should show about 1,000 DTE which is what it should be!
Thanks bud!
  #296
Old 07-05-2020, 11:04 AM
Ron Hill's Avatar
Ron Hill
Ron Hill is offline
Hey Sharkhunt what size fuel tank are you running?
  #297
Old 07-06-2020, 11:39 AM
ASizzle's Avatar
ASizzle
ASizzle is offline
4wd Low
Great find! Thanks! One quick question for you. I'm not clear on the impact of the TTPMS on the fuel tank. I have the TTPMS installed. how does that impact the coding?
  #298
Old 07-06-2020, 11:51 AM
Rich53's Avatar
Rich53
Rich53 is offline
I am not the expert on this, but in the end as I understand it all the thigh bone is connected to the hip bone, so a lot of the programming is conditional, that is a given setting that you are modifying is also read by other features/settings, so it is looking for certain values as well. So in this case, with TPMS, it looks for a different value, one of a few, in this line of code, than if there isn't TPMS. Hence the conditional programming. You will see this on other lines of code as well, where it will tell you to make the code line this value if you have this, or this value if you have that.
  #299
Old 07-06-2020, 12:12 PM
ZooDad's Avatar
ZooDad
ZooDad is offline
Rich53 is basically correct
min this data set there are four (4) different “features” with on/off values
Air Suspension control - on/off
Trailer TPMS - On/off
Downshift indicator - on/off
Then
Fuel Level either PCM or IPC with each of the above items in on/off state
So lets say you do not have TTPMS enabled today and stock tank. Your value is 4. Then you install a larger tank. Change to 0. When you get a trailer and purchase the TTPMS kit you would change your value to 2
I hope that all makes sense
Keith
  #300
Old 07-07-2020, 07:07 AM
fleming23's Avatar
fleming23
fleming23 is offline
First, i'm not new to Forscan, I've made several changes in the past. That said, is anyone having issues with Forscan not recognizing their 2020s? I was going to update my fuel tank size this morning and it says vehicle not recognized, contact developers.
Quick Reply: 2020-2022 Super Duty FORScan Spreadsheet
