2020-2022 Super Duty FORScan Spreadsheet
#197
#198
2020 Tremor/sport pkg F250.
Quick question:
RE-- Enable autoregen checkbox. Went into the non as built file for IPC and there is no listing for auto regen or the like. I then went to the non as built PCM and there were 3 options: 1. Less manual regen initiation. 2. Manual regen initiation 3. Manual regen w/active regen inhibit. I know the spreadsheet says # 3, but since it didnt read the same, wanted to be sure #3 is what I should choose?
Quick question:
EDIT: Got this to work tonight. Went into the IPC (plain english) and found the correct field called "Auto Regeneration Control", which I set to "Enable". Then went to the PCM (plain english) and chose #3 as shown above. This combo worked to enable the checkbox under the "Settings" tab on the instrument cluster, and I was able to select/deselect the box. When deselected, a message popped up saying exhaust regeneration off.
#199
And on a related note, does changing the values in one place then rewrite the values in the other place? Like if I enable something in the plain english side, and it works, will the as-built side then reflect the new hex values? I guess I could probably look, but I'm still tippy-toeing around with it until I get a better feel for what causes what, etc.
#200
I haven't seen this one yet so I'll ask...Anybody get the enable auto regen check box to show up and be usable on the 2020s? While in Forscan and connected to the truck today I looked for something that looked like it in the IPC plain english side (per the 2017+ Forscan sheet) and didn't see anything. The 2020 sheet doesn't have it listed, so maybe its not been found yet. Thanks!
#201
New to this FORScan stuff. Went from a 2013 F150 FX4 to a 2020 F250 Tremor 7.3L.
Anyways messed with most everything seen here that I wanted/understood what the change was a week ago and all good. One thing I wanted was windows closed. Tried the as built notes from 2017-2019 sheets with no luck/getting not compatible errors. So decided to adventure on my own.
Found the combo. It took 4 changes all in English.
Global windows close (takes 4 actions)
BCM (English) Global windows close (Remote).
DDM (English) Global windows close (Enabled).
IPC (English) Global windows close (Enabled). This added a check box option in settings/advanced settings/vehicle/windows for closing them.
PDM (English) Global windows close (Enabled). (Do this one and not DDM and only the passenger window closed. Had me scratching my head for a bit.)
I did see some options here and there in the English files about the rear windows but didn't mess with any to see what happens. It would be a rare occasion for the rears to ever be down.
I sure wish there as a way to over ride the mirror spot lights in motion but as far as I can tell/have read the only way to do that is altering the wiring.
Tom
Tom
I gave this a shot and I know have Global Close on the front windows.
I saw a mention of Rear Door Unit within PDM & DDM. There were option to disable and enable. I may give that a try to see if the Rear windows will also open/close globally.
#202
2020 F350. I have the "DPF Filter %" working but have not been able to get the "Enable Auto-Regen Checkbox" to work. I go to the PCM and make the change form #1 to #3 and it gives me a Service procedure has been interrupted. What am I doing wrong? Has anyone got this to work on a 2020 limited?
#203
Anyone else tried the Dpf% on a 2020? I did and it messed up my bed camera. I know it said in the description to change it to certain values but didn’t work.
And the stupid double horn honk didn’t work either. But I was able to change temp above gauges and fog lights with high beems.
Any ideas on Dpf or horn honk?
#204
For the DPF%:
IPC - As Built, DPF % on screen, 720-07-02, Original Value: 0742, 48C1 New Value: 0F42, 48C9. I only changed the "7" to an "F". Don't forget this important note: Some trucks will report a camera error after making this modification. To avoid that, make your update according to the following: If your original default value is 0, change to 8; if 1, change to 9; if 2 then A; if 3 then B; if 4 then C; if 5 then D; if 6 then E, if 7 then F.
For the horn Honk:
BdyCM Module (plain English), Double Honk on leaving cabin, Original Value: Enabled, New Value: Disabled
#205
#206
#208
Thanks! Got the horn disabled by looking in the plain English. That worked. Any idea on Dpf?
I did on my 2020 and both worked. Here is what I did.
For the DPF%:
For the horn Honk:
For the DPF%:
For the horn Honk:
#209
A lot of people are having the bed camera problem, myself included. There is a separate thread on this. Some, like me, added the DPF screen, and assumed that is the problem, however on mine I have deleted the DPF screen and still a problem. But some are having the issue and never played with FORScan on the truck. One suggestion was lose connection on the camera behind the third brake light, some seemed to fix theirs that way, I pulled it apart, used some electrical contact cleaner on them, put it back together, still have a problem. In most
cases being reported it is intermittent, what are your symptoms?
#210
Before I changed it the rear bed camera worked. Added Dpf through forscan and the Dpf% screen appeared. But when I cycled through the camera options the one for the bed was like an 80s tv screen. I could maybe sometimes see the bed but most of the time it was blurry. All over cameras were fine. Changed back and the camera worked. Never had any issues with any of the camera. I got 3,000 miles on my truck.
