2020-2022 Super Duty FORScan Spreadsheet
#181
#182
#183
https://www.ford-trucks.com/forums/1...-idle-mod.html
https://www.thoroughbreddiesel.com/1...SABEgJIQPD_BwE
#184
I got it to work on mine. I’m sorry but I don’t remember which I used. I believe I used the door chime disable from the 17-19 sheet. Don’t forget to backup your current BCM config. I keep the original saved and I keep a second one called current when I make individual changes.
#185
#186
I am looking for info on the door lock key pad install on an 2020 F550 XL. I went by a post from another member to make this needed addition..... The changes that were posted in another thread listed the 2017+ instructions. But the values to change were not working (one was already set at the new value and the other I changed). I am guessing the 2020 has changes to it from the 17 to 19 models. I need to activate the door keypad unit I installed on this brand new XL truck. The last thread said it worked on 17+, so I installed it, but it does not. If you have any updates to the spreadsheet that will help, please let me know.
Thanks Tim
Thanks Tim
#187
Thanks Tim
Thanks Tim
Let me take a look and see what I can find
Keith
#188
Thanks Tim
Thanks Tim
You did not list what data set you tried, but try this:
KeyPad 726-31-01 xxxx xxx* xxxx 0=Disable 1=Enable
Let us know.
Keith
#189
Thanks Tim
Thanks Tim
It was in the plain english section.
Is the 550 Forscan different than the 350?
#190
I want to thank LivnItUp, EpicCowLick and all the other members who have tested and contributed to the ForScan sheet efforts
Since there are some differences (and similarities) in the 2020MY I am starting a new ForScan sheet.
As of now the info is "somewhat limited", but I'm sure there is additional info out there.
If you are new to ForScan please take the time to read and watch LivnItUp tutorial. LivItUp ForScan Info It will answer over 90% of the basic questions.
If you have info you would like to share, please do so.
I am hopeful that we will be able to continue drilling into each module.
Enjoy
2020 Super Duty ForScan Sheet
ZooDad
Enjoy
ZooDad
My big wish right now - enabling the extra Tremor offroad mode on my 2020 F350!
#192
I haven't seen this one yet so I'll ask...Anybody get the enable auto regen check box to show up and be usable on the 2020s? While in Forscan and connected to the truck today I looked for something that looked like it in the IPC plain english side (per the 2017+ Forscan sheet) and didn't see anything. The 2020 sheet doesn't have it listed, so maybe its not been found yet. Thanks!
#194
#195
Keith- I got it to go, just as they said... it was available to change in the BCM plain english module. I changed the value, confirmed it and cycled the keys. I got the door code and the keypad is now activated. thanks for your help on this 2020 F550XL 4x4 crew cab chassis
Keith
The following users liked this post:
