2020-2022 Super Duty FORScan Spreadsheet
#226
Got it back to original by restoring the SCCM module to factory. Now the steering wheel controls are correct!
I had tried to change the turn signal flash count to a larger number from three (with two added when trailering). If I want to change to four flashes, just what should the second column values be? My spreadsheet shows only three digits in the second column, but the software has four. Doesn't take much to confuse me I guess...
#227
#228
Glad to hear you got it fixed.
ZooDad
#229
Changing Turn Signal Flash Count
[QUOTE=ZooDad;19290123]So can you post up what you changed from and to for future readers
To change the turn signal flash count from "original" (mine was an original three flash count):
Module SCCM, 724-01-01
Change second number in second column. My original second number was changed to A, and now have five flashes that automatically cancels with the lane changing feature.
#230
[QUOTE=spud1223;19290207]
Good you got it
you are correct it is only the second digit in the second set
ZooDad
ZooDad
#231
2020 DTE issue resolved
Big news for 2020 60 gallon fuel tank upgrade guys. I had Ron-Hill and sharkhunt do some testing and they got positive results.
So after researching about 20-25 different trucks and AsBuilt comparisons I found one difference.
so The normal IPC change.
IPC 720-03-01 xxxX XXxx xxx
Make the same change in AsBuilt In the PCM
PCM 7E0-01-04 xxxX XXxx xxxx
Thanks to the ForScan Team for shooting me this info
I have updated the spreadsheet
Have a great and safe weekend.
ZooDad
ZooDad
The following users liked this post:
#232
so The normal IPC change. 720-03-01 xxxX XXxx xxx
Make this change in AsBuilt
also make this change
PCM 7E0-01-04 xxx5 xxxx xxxx to xxx7 xxxx xxxx
this is the LB setting
ZooDad
ZooDad
Big thanks to ZooDad made the change this morning and looks like it was the ticket!!
really appreciate the help ZooDad! No more guessing on DTE calculations!!
#233
#234
#235
#236
I made the changes, the DTE immediately went up to 760. The tank is essentially full, 17 miles since i filled, the truck is showing an average MPG at the moment of about 17.5, the trip for the 17 miles was showing about 16.8.
I am never sure what mpg it uses to calculate the DTE, but if it uses either of those I would have expected the range with 60 gallons to pop something closer to 950 or 1,000.
The calculated DTE feels more like it is assuming that it has the LB tank of 48 gallons, rather than actually taking the IPC change, it is just reflecting the LB change in the PCM.
What do you think?
What do you think?
#237
What do you think?
What do you think?
As they drive the DTE contributed to climb
drive it a while and see what happens
#238
Okay, I will see what happens. when I drove it locally the DTE started going down, as the fuel economy got worse, will be interesting to see what happens next time I am on the highway.
Is there any other consequence to making the truck think it is the long wheelbase? Mine has the active steering for instance, I wonder if the correction curves in the software that control that are specific to wheelbase.
#239
#240
