2020-2022 Super Duty FORScan Spreadsheet
The following 4 users liked this post by Y2KW57:
2020-2021 Super Duty FORScan Spreadsheet
Forscan Spreadsheet for 2020+ trucks:2020+ Forscan Spreadsheet Link
*MODERATOR'S NOTE:*
AS OF DECEMBER 2019, *OWNERS OF _2020_ MODEL YEAR SUPER DUTY VEHICLES BEGAN REPORTING SIGNIFICANT DIFFERENCES IN FORSCAN BEHAVIOR AND/OR PARAMETERS WHEN COMPARED TO 2017-2019*.
*IF YOU HAVE A _2020+_ MODEL YEAR SUPER DUTY, IT IS STRONGLY SUGGESTED THAT YOU USE THE INFORMATION IN OF THIS THREAD.
IF YOU HAVE A _2017-19_ MODEL YEAR SUPER DUTY, IT IS STRONGLY SUGGESTED THAT YOU USE THE INFORMATION IN THE 2017-19 THREAD LOCATED HERE 2017-2019 Forscan Thread
I will try when my 2020 arrives but hey - at least I got my VIN today!
*MODERATOR'S NOTE:*
Last edited by System; 07-11-2020 at 08:45 AM. Reason: Edited to add a link to the spreadsheet in the original post.
I haven't been following this thread closely lately so forgive me if this has already been posted. I just pulled the as-built values of a 2020 Lariat F250 6.7L Tremor package (VIN: 1FT8W2BT8LEC00216) and it seems like a new format BCM is being used compared to the 2017-19 Super Duties so the current 2017-19 BCM FORScan spreadsheet shouldn't be used for the 2020s because the locations are different.
Example: The VIN coding area of the 2020 BCM now is at 726-12-01 instead of 726-09-01 so the new locations for the various BCM FORScan mods will need to be figured out and a new BCM spreadsheet will be needed. I haven't examined the other modules in the 2020 yet but thought I'd point this out if it hadn't been mentioned previously.
2020 Super Duty Forscan???
Just got my new 2020 F-450 in yesterday. Many Forscan codes I have used previously on my 2018 F-350 no longer seem to work on the 2020. Anyone know how to disable the double honk horn when the engine is running and you get out of the truck?
"Double Horn Honk Disable BdyCM as built 726-41-02 xxx1 xxxx xxxx xxx0 xxxx xxxx" as listed in the 2017+ spreadsheet does not work. From factory, the 2020 already has a "0" in that place. Thoughts?
Also, I cannot seem to access any of the IPC settings either.
Thanks!
Moderator's Edit: Copied another post by CWay (from a different thread) below, due to its relevance and potential importance to other 2020 Super Duty owners.
Just got my 2020 F-450 in yesterday...been on order since late September. Tried out some Forscan functions that I enjoyed on my 2018 350, but some work and some don't. I'm still working off of the 2017+ spreadsheet, but they have definitely changed some coding around for the 2020's. For instance, the double honk horn thing already has the code from factory that the spreadsheet says to change it to. I experimented a bit, but cannot find a way to disable the double honk yet. Hopefully a new 2020 spreadsheet starts coming together soon. I was able to change the blinker count from 3 to 4 blinks with a single tap, using the old codes listed in the 2017+ spreadsheet. I imagine a handful of other functions have not changed as well, but many of them have
Thanks!
Last edited by Y2KW57; 12-16-2019 at 12:07 PM. Reason: To add additional information from CWay on 2020 changes.
Thanks!
Thanks!
What year is your truck? My experience is with the F150s but I find it odd that your truck's default had the double horn honk disabled unless you have a 2020 because the 2020 Super Duties have a different format BCM than the 2017-19 Super Duties so you can't use any of the F150/F250 BCM spreadsheets because all the features like double horn honk are now at different address locations and the 2020 SD BCM hasn't been mapped out yet.
The following users liked this post:
Block 41
726I9G1010000010071
726I9G2200000000191
The value to change wasn't already a 0?
I also want Bambi mode, which is in the BCM. Did you try that by chance?
