2020-2022 Super Duty FORScan Spreadsheet
#436
OK I would start by restoring your back up and confirm that your trailer lights are operational.
Then I would start by making one change at a time using the AsBuilt Data on the spreadsheet. I do not normally use the Plain English side as I can not see what else it changes. With Ford changing addresses on numerous items, it is just too easy to miss something and get an undesirable result.
Save your current BCM data file. Once you get enough posts for PM we'll talk about sending the file so I can see if I can find what happened.
Let us know how it goes.
ZooDad
ZooDad
Thanks for the advice
Cheers!
#438
ZooDad
ZooDad
#439
Get your VIN and go to Ford AsBuilt. The first time you go to the page it will ask for your country
after you select it will take you to the general page. Reload the original page and you will see where to enter your vin. Then you can download you entire AsBuilt file
once you have that you can view your AsBuilt data in an html viewer or excel
the BCM module is 726
Bad news is you will have to go line by line to find the differences
Or I will post a DropBox link. Save your current BCM AsBuilt and upload that and your full file from Ford and I will compare and send you the needed info
Let me know
ZooDad
#440
No unfortunately it doesn’t do it automatically but fear not there is a way
Let me know
ZooDad
Let me know
ZooDad
#441
If the above link doesn't work, try https://www.motorcraftservice.com/AsBuilt
ZooDad
#442
#443
#444
Edit: Here is the link if you want a double check
LLK AsBuilt
ZooDad
#446
Let me know if you want the DB link to upload the files
LLK AsBuilt
ZooDad
LLK AsBuilt
ZooDad
While making the changes, I did notice a few things. One, the downloads from the Motorcraft service as built values were incomplete. While hooked up to forscan, there were a few modules that had several more lines of values that were not list from the downloads.
The second thing I noticed was, I had some changes that I noticed in the IPMA modules that I could not write the values. The process kept terminating before the change was complete.
I will try to upload my files to the DB link
LK
#447
So I just finished running back to the trailer after restoring all the values that were changed, and unfortunately the lights still do not come on.
LK
LK
Drive folder LLK
#448
of the Dropbox link doesn’t allow you to upload use this link for Google drive
Drive folder LLK
Drive folder LLK
#449
I’ll let you know what I find
on edit. Where did you upload them. I am not seeing them
#450
