2020-2022 Super Duty FORScan Spreadsheet
#331
#334
So, I've screwed the pooch somehow. Though I am not sure where, why, or how!
I was only trying to change a few things, when stuff went sideways!
I have a 2020 Lariat Ultimate.
My problem is this.
When I remote start the truck, instead of the mirrors folding inward, like they did when I got it, (700 miles ago...) they now adjust all the way down!
The glass itself goes all the way down, until it can go no further, and the mirror housing stays put!
Well, I figured, start over, I do have a backup of everything...
I restored all of the original settings, (I think) but no love.
It still does it! (Both mirrors)
All I really want is to add temperatures above guages. Get a few more blinks. Have control of my fog lights so they don't turn off unless I tell them to. Get rid of all nanny bells, seatbelts, ignition, etc..
And most importantly, and the reason I discovered this forum and Forscan in the first place a few weeks ago, I want the power points to stay on even when the truck is off. My phone, and any of the kids BS I leave in there, should charge while we are at the beach, or whatever.
Oh, and I don't want the truck to turn off after 30 minutes of idle..
But most importantly right now, is fixing this mirror issue.
Anybody have any ideas?
My problem is this.
#336
#339
I would have thought it would have been 335 in the BCM Module Tab. I am still playing around with Forscan so I could be totally out of the ballpark.
#341
#342
mine also went fussy on the upper bed camera
I can report with a '20 Lariat Crew Cab 6.7L with CHMSL Camera (the camera above the bed) the %DPF does show up on the Instrument Cluster using the Coding below, but as a result the CHMSL Camera goes fuzzy. So it only partially worked as indicated (I put it back so the upper camera will work properly, reverse tailgate camera was fine).
Before:
After:
Before:
After:
IPC module 720-07-02 before mod "0742" "48C1" NOW BECAME 0F42 48C9 ( 2020 f250 6.7 diesel ) so after mod does the c1 become c9 maybe that where the fussy comes in
#343
Use the sheet for the dpd%
not too fussy that i can't use it..i would rather show % diesel filter full . but my finished numbers i think changed
I used the coding from the spread sheet and had zero problems with any of my cameras
#344
#345
from your mouth to his ears
i really hope so...... i'm done playing for a while.....i did notice the top mounted bed camera got a little out of focus..but nothing i can't deal with considering it's only used for 5th wheel hookup
