2020-2022 Super Duty FORScan Spreadsheet
#271
Dumb question
Big news for 2020 60 gallon fuel tank upgrade guys. I had Ron-Hill and sharkhunt do some testing and they got positive results.
So after researching about 20-25 different trucks and AsBuilt comparisons I found one difference.
so The normal IPC change.
IPC 720-03-01 xxxX XXxx xxx
Make the same change in AsBuilt In the PCM
PCM 7E0-01-04 xxxX XXxx xxxx
Thanks to the ForScan Team for shooting me this info
I have updated the spreadsheet
Have a great and safe weekend.
ZooDad
ZooDad
#273
Hey Guys...today I am doing forscan on my 2020. Quick question. On the spreadsheet it says navigation in motion (which I believe allows you to add an address while in motion) but then it says it will change speed signs and voice. Does anyone know what the changes are to the signs and the voice? Thank you.
#274
The truck believes it is American Samoa I guess, at any rate it follows European convention, so speed limits are shown with a red circle around them, and it uses British English. I made the change and really the only difference I saw was the speed limit info.
however, making the Change also eliminates the 911 assist function, since 911 doesn’t work in American Samoa. I like that feature, so I put it back to stock. But I do miss being able to enter addresses and scroll through my USB music.
#275
Now my next issue is I cannot get into or even locate the IPC module which houses my 2 favorite Forscan mods from my 2017...Temp above gauges and % DPF screen. I have tried several times and now matter what I do Forscan won't show IPC.
Thank you to anyone who can help!
#276
Forscan issue
Im not exactly new to forscan , but new to my 2020 f350 tremor, i coded in some things and made adjustments in the cluster and now i do not have the lights coming on when locking and unlocking or opening doors as previous, and i didnt change anything associated to that, all help is appreciated.
#277
#278
we use it on our patrol units
ZooDad
#279
Long bed dte
or do I change the 5 to a 7 like your quote says???
#280
Same question just for zoo dad
ZooDad
ZooDad
So do I use the spread sheet that says make the same change to the pcm
#281
#283
DTE ISSUE RESOLVED
Great news for all the larger than stock fuel tank people.
I found an odd entry in the IPC where the fuel level is captured from either the IPC or PCM. My 2020 and three others are all set to PCM. I had the change to IPC tested and voila the DTE rose to the calculated level it should be.
The change has been made in the spreadsheet.
IPC 720-09-01 xx*x xxxx xxxx
If your current value is 4 change to 0
If your current value is 6 change to 2
The difference is if you have Trailer TPMS (TTPMS) enabled
ZooDad
ZooDad
#284
This. I would really like to have my DTE read correctly. I have it set through forscan to the 60 gal tank. There must be two spots to change it, hopefully forscan will map it out soon.
#285
ZooDad
ZooDad
Super stoked! I am curious to see what those with stock tire heights and reasonable driving habits show for DTE. Let’s see those 999s, will we see 999+ on this generation? Thanks ZooDad!
