2020-2022 Super Duty FORScan Spreadsheet
#391
Gents, is the spreadsheet updated for the double honk?
I bought one of those raptor lights that plugs into the headlight harness. I like to use the auto setting on my headlights. However, if you use auto, the raptor light only works when the headlights are on, so not during the day. Which line would modify to keep the side markers on during the day in auto (which would keep the grille lit up I believe). Hopefully that makes sense.
Also, anyone change their tire size to 35" yet?
Anyone confirm the temps on gauges work?
#392
Guages g2g
#393
726-38-01 xxxx xxxx x1xx - DRL Include Parking Lamp
726-85-01 x1xx = Exterior Lighting DRL with Parking Lamps On
As far as the 35" tire the Tremor has that stock, so I would use that data as a starting point and make adjustments from there.
ZooDad
#394
Does the spreadsheet update with the new info? I just got a 2020 F-350 and want to make some changes but wasn't sure if the spreadsheet on the first post is current? I am new to forscan and here the 2020's are quite different then the previous models so looking for a spreadsheet with proven mods that wont throw a check engine light.
#395
#1 thing with ForScan, make a backup of all modules and download your As-Built from Ford and store in a safe place.
ZooDad
#396
Yes the spreadsheet is current. Not every mod that can be done is listed. Some changes are the same as MY17-19. If you are interested in a specific change that is not listed we can check on it.
ZooDad
ZooDad
#398
2020 FORSCAN help...found the setting for tire circumference. Went to the tire website and did calculations based on inflated tire diameter. Speedo app shows I’m going 3mph slower than speedo.
Inflated diameter = 34.76
Circumference = 34.76 x 3.1416 = 109.20”
109.20” x 25.4 = 2773.731mm
Set value in FORSCAN to 2774
am I doing this wrong
#399
#400
I would start at 35.5” and see what that get you. Your tire pressure will also affect this. But not by much.
ZooDad
#401
Here is the link
Ford As-Built
The first time you go to the page you will be prompted for country. Select USA. Once page loads refresh or reload from the link. You will get the As-Built page with VIN entry field
Hope this helps
ZooDad
#402
You don’t need to register
Here is the link
Ford As-Built
Hope this helps
ZooDad
Here is the link
Ford As-Built
Hope this helps
ZooDad
#404
#405
