2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2020-2022 Super Duty FORScan Spreadsheet
Old 05-22-2020, 03:11 PM
ZooDad's Avatar
ZooDad
ZooDad is online now
Originally Posted by Rich53
Okay, thanks. It is clear that I am ignorant on how all of the FORScan stuff works, just happy that it does. Wish we could figure out why the DPF% screen on the 2020's is taking out the bed camera, hard to see how they are related.
Hit me up on PM.
I have enabled mine with no camera issues.
  #242
Old 05-23-2020, 11:08 AM
WaxOnWaxOff's Avatar
WaxOnWaxOff
WaxOnWaxOff is offline
*duplicate*
  #243
WaxOnWaxOff
Originally Posted by ZooDad
Hit me up on PM.
Same, no issues on mine either.
  #244
Old 05-23-2020, 01:46 PM
longhaultransport's Avatar
longhaultransport
longhaultransport is offline
Mine also, no issues, but I only have a few thousand miles on it.
  #245
Old 05-26-2020, 06:36 PM
kenny400ex's Avatar
kenny400ex
kenny400ex is offline
Tried doing some Forscan changes this past weekend. I added DPF% and after a few minutes the camera flashed and I lost the third brake light camera. I tried changing back to the factory settings with no luck on the camera. I drove the truck for about 3 hours and it finally went back to working. I sent my files to Zoodad and he is looking over them and will come up with a fix, He also helped me with another issue that was a mistake on my part. Some where in the process I lost the entry lights as well. Did Heated/vented seats-HSW on home screen, DRL w/Turn Signal, Bambi Mode, DRL Full Brightness w/Headlights, Average Speed to Trip/Fuel Menu and disabled triple ding at start up,
  #246
Old 05-27-2020, 11:39 PM
bwbryant85's Avatar
bwbryant85
bwbryant85 is offline
2020 F-350 PS Lariat
Made the following changes yesterday and everything seems to be working great.
disable double honk w/out keys
DPF %
TPMS lower for rear
increased turn signal flash
Thanks for everyone that has put work into being able to do this. Seems as most dealers do not know what to do or want to charge you.
  #247
Old 05-28-2020, 12:31 AM
jdnariz's Avatar
jdnariz
jdnariz is offline
I am interested to see if anyone has tried changing the power running board delay after a door is closed. I'll open the back door to put something or someone inside, close the door and the running boards immediately retract. The I open the front door to get in and they come right back out only to be there as long as it takes me to get in and close the door.
I'd like to add some delay into the retraction so that they don't go in and out so much. This will wear everything out much sooner than necessary.
Thanks in advance,
Jim
2020 F350 Lariat, Crew Cab 4x4 short bed
  #248
Old 05-29-2020, 06:52 AM
greg_mc's Avatar
greg_mc
greg_mc is offline
Has anyone been able to change there tire size and disable the tpms on the 2020 yet using forscan?
Thanks, Greg
  #249
Old 05-29-2020, 09:49 AM
Spikescj7's Avatar
Spikescj7
Spikescj7 is offline
[QUOTE=greg_mc;19304194]Has anyone been able to change there tire size and disable the tpms on the 2020 yet using forscan?
Thanks, Greg[/QUOTE
If you change the tire size over 35” (which is basically what the 4x4’s come with), it will set off all sort of codes. ABS and some other weird ones. I installed the Rough Country in-line speed calibrator and my speed is within 1mph of the gps at 75mph with 37’s. This fixed the DTE calculation as well.
The TPMS sensor settings is easy in the non asbuilt setting. See what tab the spreadsheet says and select the non asbuilt.
  #250
Old 05-29-2020, 11:55 AM
bheath26's Avatar
bheath26
bheath26 is offline
Cameras
Has anyone found a way to use the cameras over 5mph? and use the cargo light while driving?
  #251
Old 05-29-2020, 04:01 PM
Charlie_Lake_Conroe's Avatar
Charlie_Lake_Conroe
Charlie_Lake_Conroe is offline
Door Chimes
Originally Posted by Sharkhunt
About the door chime, my 20 has a fob but my 19 has a key. Both are disabled successfully, but O don’t have a 20 with a key (which I think is what you’re asking).
With the help of ZooDad, I was finally successful in disabling all the chimes. Ended up being PBKAC (problem between keyboard and chair)
  #252
Old 05-29-2020, 04:28 PM
Charlie_Lake_Conroe
Global windows close
Originally Posted by wolfs4evr
New to this FORScan stuff. Went from a 2013 F150 FX4 to a 2020 F250 Tremor 7.3L.
Anyways messed with most everything seen here that I wanted/understood what the change was a week ago and all good. One thing I wanted was windows closed. Tried the as built notes from 2017-2019 sheets with no luck/getting not compatible errors. So decided to adventure on my own.
Found the combo. It took 4 changes all in English.
Global windows close (takes 4 actions)
BCM (English) Global windows close (Remote).
DDM (English) Global windows close (Enabled).
IPC (English) Global windows close (Enabled). This added a check box option in settings/advanced settings/vehicle/windows for closing them.
PDM (English) Global windows close (Enabled). (Do this one and not DDM and only the passenger window closed. Had me scratching my head for a bit.)
I did see some options here and there in the English files about the rear windows but didn't mess with any to see what happens. It would be a rare occasion for the rears to ever be down.
I sure wish there as a way to over ride the mirror spot lights in motion but as far as I can tell/have read the only way to do that is altering the wiring.
Tom
Originally Posted by djfergi
Thank you!!
I gave this a shot and I know have Global Close on the front windows.
I saw a mention of Rear Door Unit within PDM & DDM. There were option to disable and enable. I may give that a try to see if the Rear windows will also open/close globally.
I was thinking of tackling the Global Window Open/Close this weekend. I tried the commands from the key fob already. The close does not work, but the open commands open the front windows only before any changes. I was wondering if dfergi or wolfs4evr captured the actual values that changed vs. only the plain english changes? I could try the values instead of plain english so we can start adding to ZooDad's sheet.
  #253
Old 05-29-2020, 04:30 PM
ZooDad's Avatar
ZooDad
Not possible using ForScan.
  #254
Old 05-29-2020, 10:58 PM
bheath26's Avatar
bheath26
bheath26 is offline
Thanks! Guess I shoulda stuck with dodge
  #255
Old 05-30-2020, 09:47 AM
longhaultransport
The cameras in motion is possible, just not with FORScan.
Aftermarket adapter does work.
Quick Reply: 2020-2022 Super Duty FORScan Spreadsheet
