Sync 3.4 Version 20021 Update
Old Jun 30, 2020 | 06:45 AM
  #76
TJ jenifer's Avatar
TJ jenifer
I have a question.. when i update my system it says that (5u5t-14g381-EB) cant be found. Any way i can fix this?
Old Jun 30, 2020 | 08:14 AM
  #77
leonmckee's Avatar
leonmckee
Verify that every single letter and number along with file structure is correct. There's no room for error to be honest.
Leon McKee
Old Jun 30, 2020 | 08:16 AM
  #78
leonmckee's Avatar
leonmckee
Originally Posted by hinzy
Leon trying to wrap my head around the point at which started here's what I did.
Is it really as simple as what you listed:
Here's what I did:
1) Formatted USB 3.0 Flash Drive to ExFAT and renamed to SYNCMYRIDE
2) Downloaded 20021 app file 5U5T-14G381-EB.tar.gz from here. This is a Ford file server.
3) Renamed file to: 5U5T-14G381-EB.tar.gz (I always standardize file names to avoid confusion)
4) Created autoinstall.lst install script:
[SYNCGen3.0_3.4.20021]
Item1 = 5U5T-14G381-EB.tar.gz
Open1 = SyncMyRide\5U5T-14G381-EB.tar.gz
Options = AutoInstall
Is the above ^ how you laid out the file on the usb drive.
I am very interested in updating to 20021 and looking for guidance.
TIA
Hinzy
Yes. There's a picture in the first post shows the file structure. The only thing I would change is remove the delay in Options.
Leon McKee
Old Jun 30, 2020 | 08:19 AM
  #79
leonmckee's Avatar
leonmckee
Just an FYI that's there's a new version 20136 of the apps file out. Here's the version for Nav units:
5U5T-14G381-ED 842Mb Sync3 v3.4.20136 15.05.2020
I've installed 20136 and, so far, no issues. I do not use USB music or Sat radio so can't confirm if those are 100% functional.
Leon McKee
Old Jun 30, 2020 | 08:42 AM
  #80
gpf2ez's Avatar
gpf2ez
I've installed 20136 and, so far, no issues. I do not use USB music or Sat radio so can' confirm if those are 100% functional.
Leon McKee
I will give this a shot this afternoon. I can test Sat radio
Old Jun 30, 2020 | 08:55 AM
  #81
kry226's Avatar
kry226
Leon McKee
Any idea if the new update enables you the ability to search through USB music while in motion? That's the one issue I have with 3.4 and why I retrograded back to a previous edition.
Old Jun 30, 2020 | 08:57 AM
  #82
leonmckee's Avatar
leonmckee
No personal experience with USB Music to be honest. I did see posts on other forums stating the USB problem(s) still exists though :-(
Leon McKee
Old Jul 1, 2020 | 05:12 PM
  #83
TJ jenifer's Avatar
TJ jenifer
Leon McKee
i believe so. I even tried copying the way u had yours.. its same message
Old Jul 1, 2020 | 08:29 PM
  #84
h20camper's Avatar
h20camper
Use FORScan to enable 'NAV In Motion'. It has been reported that will allow USB music search while in motion too.
Old Jul 1, 2020 | 08:31 PM
  #85
h20camper's Avatar
h20camper
Post a screenshot of the files and structure of your USB stick.
Old Jul 2, 2020 | 04:56 AM
  #86
kry226's Avatar
kry226
Thanks, I've done that before on my current set-up. However, doing so also deactivates the 911 emergency calling feature too, in addition to the European signage. Kinda makes my OCD tingle, but I may give 3.4 another try. One thing to note, after I reformatted and upgraded to 3.4, my Travel Link gas price area search no longer functions. When I downgraded to my current 3.3, there was no improvement. With an active route in the Nav, the route search function works as designed on both 3.3 and 3.4.
Edit to add... I just upgraded back to 3.4 with the latest map files and after a master reset, the Travel Link area fuel search miraculously works again. Only glitch I'm seeing right now is that when I get back in the truck and I had been listening to USB music, the USB music is still playing upon restart as before, but the FM radio screen is shown. Did this on two different restarts. I'll continue to monitor.
Old Jul 9, 2020 | 09:41 PM
  #87
E4WSKY's Avatar
E4WSKY
Sync 3.4 with new maps update issue
I updated to 3.4 a while ago and tried to install the new maps update and got an error.
"Installation error. This SYNC software is not compatible with the installed SYNC hardware on the vehicle."
The install guide says this happens if you have Sync 2.
Has anyone else successfully updated the new maps file who also has updated to 3.4?
Thank you!
Old Jul 9, 2020 | 10:35 PM
  #88
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Thank you!
Check the autoinstall file. I would be willing to bet it is looking for build 19250
I’ll have mine tomorrow I’ll check it as well
ZooDad
Old Jul 10, 2020 | 02:42 PM
  #89
E4WSKY's Avatar
E4WSKY
ZooDad
Here is the Autoinstall file:
[SYNCGen3.0_2.0.16074_PRODUCT]
Item1 = HB5T-14G386-TAB
Open1 = SyncMyRide\HB5T-14G386-TAB.tar.gz
Item2 = HB5T-14G386-TKB
Open2 = SyncMyRide\HB5T-14G386-TKB.tar.gz
Item3 = JR3T-14G424-CE
Open3 = SyncMyRide\JR3T-14G424-CE.tar.gz
Item4 = GB5T-14G386-ZA
Open4 = SyncMyRide\GB5T-14G386-ZA.tar.gz
[SYNCGen3.0_2.0.16074]
Item1 = JR3T-14G421-CE
Open1 = SyncMyRide\JR3T-14G421-CE.tar.gz
Options = AutoInstall, Include, Transaction
[SYNCGen3.0_ALL]
Item2 = JR3T-14G422-CF
Open2 = SyncMyRide\JR3T-14G422-CF.tar.gz
Item3 = JR3T-14G423-CB
Open3 = SyncMyRide\JR3T-14G423-CB.tar.gz
Options = Delay, AutoInstall, Include, Transaction
Old Jul 11, 2020 | 02:52 PM
  #90
ZooDad's Avatar
ZooDad
[SYNCGen3.0_ALL]
something doesn’t look right. It’s looking for an older version of Sync
I we’ll go through my Sync file notes this afternoon and see what I can figure out. You should be able to download the correct files and use your license
I’ll let you know
ZooDad
