Code red on 2002 7.3 Exc!
Old Mar 5, 2020 | 06:35 PM
  #121
Mod7.3's Avatar
Mod7.3
Originally Posted by KubotaOrange76
Looks similar to me,
it sure does look similar. and just from a misplaced/misfunctioning solenoid
Old Mar 5, 2020 | 07:10 PM
  #122
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You can test the solenoid, but I am not sure what the parameters are to indicate operational or faulty. I seem to recall 6.5 ohms from a post by aawlberninf350, but I could be wrong on both of those.
I will look for it when I get a chance later if you have not found it.
All bets were off when using Forscan with the 42 pin disconnected...
Old Mar 5, 2020 | 07:22 PM
  #123
Mod7.3's Avatar
Mod7.3
ya I was a dumb ***
Old Mar 5, 2020 | 08:09 PM
  #124
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
No thats my title
here scroll to post 10
https://www.ford-trucks.com/forums/1...whats-bad.html
Old Mar 5, 2020 | 08:18 PM
  #125
KubotaOrange76
“Four things commonly go wrong with the IPR:
In order....
1. Debris in the pilot valve:
Using a small screwdriver, gently push in on the end of the pilot valve assembly. You should feel the valve move about 1/8" in and out and return to its seat with a bit of snap.
Should the action of the valve be sticky at any point, use a combination of solvent, screwdriver motion and compressed air to clear any debris that may be trapped in its motion.
2. Debris in the actuator piston area:
Thoroughly clean the actuator body, piston, guide and pin. Lubricate them well with a very thin oil or solvent. Assemble the actuator only, but do not tighten. With the solvent as the lubricant, the piston should move freely.
I.E. if you shake the actuator assembly, you should hear the piston sliding around freely. This will not happen with motor oil as the lubricant.
3. Bad/Damaged external O Rings.
4. Defective Coil: IPR Coil Test OHMS: 10.2 - 10.6
Ford sells a rebuild kit consisting of the O Rings and a replacement solenoid nut. The Solenoid is NOT sold by itself. It comes only with a new Valve Assy.
Prior to considering replacing any part, some additional testing should be done.”
“2e. Injector Control Pressure Duty Cycle (ICP %) Spec: 10%-12% at idle, engine at 140F or > / NTE 20% while Cranking / 65% is closed (IPR Suspect)”
Old Mar 5, 2020 | 10:13 PM
  #126
Mod7.3's Avatar
Mod7.3
You are probably right...
No, they do not seem OK... IPR should NOT be 65% when trying to start the engine. It should be no more than 20% when trying to start the engine.
Not likely... This is a very simple part of the truck and it will let you know if you did it wrong.
Maybe, but your readings indicate a HPO (high pressure oil) issue. 500 ICP is minimum for starting and IPR should be near 20%. If you unplugged the ICP, it will default to 725 by the PCM, so the problem is NOT likely the ICP sensor itself.
Your right, it is unlikely. Seeing as how the 42 pin connector was not reconnected at one point, you should retrace your steps and look for anything obvious. Did you rebuild the IPR or anything else associated with the HPO other than the HPOP lines?
Your immediate no start issue is NOT a gasket problem.
Your truck not starting might be a GP issue, but the HPO clues based on the readings is where your bloodhound should be sniffing.
Typically yes...
Do you hear the fuel pump come on when you turn the key to on? Open the drain valved on the back of the fuel bowl after turning the key to on and see if fuel comes spraying out.
Let us know what you see and find...
bit of good news. Buzz test went off without a hitch. Sounded right and forscan agreed.
Old Mar 5, 2020 | 11:29 PM
  #127
Mod7.3's Avatar
Mod7.3
In order....
yes I got the kit and replaced the ipr orings and cleaned it.
Tested solenoid below. Seems ok? Would be nice to have good one to test as many of the videos suggest. Ford here in Calgary wants 384 ca dollars 😞 for new IPR. About 150 in us I recall.
Could also be hpop
pump too I guess but was working before I did maintenance
does this look right ?
Old Mar 6, 2020 | 05:11 AM
  #128
FordTruckNoob's Avatar
FordTruckNoob
It looks like Sous and KubotaOrange76 have got you going down the right path now.I have bunch or IPR coils I can send you if you need them.
Old Mar 6, 2020 | 07:25 AM
  #129
KubotaOrange76
looks like service manual says good spec is 10.2-10.6,
Im thinking stuck ipr? issues 1 or 2 above? You already replaced the ipr rings when you disassembled earlier?
Where are you located? I Have two good oem working iprs for spares i could loan you one.
You had a no-start condition before you took it all apart?
Check it closely for cracks on both ends at the plastic portion and where the connector is.
Old Mar 6, 2020 | 08:12 AM
  #130
Sous's Avatar
Sous
FTE Emeritus
Unlikely it is the HPOP if it was working prior to the maintenance performed.
As Chris said above...
What was going on prior to the maintenance?
Old Mar 6, 2020 | 08:36 AM
  #131
slowsure's Avatar
slowsure
If you rebuilt/resealed fuel bowl in your maintenance.
I would check post fuel bowl fuel pressure. Should be somewhere around 50-65 psi.
Unfortunately you cant get it from a PID in Forscan, you will have to hook a gauge in-line post fuel bowl.
Looks like you replaced FPR (fuel pressure regulator) with a new one. Maybe something not lined up here?
If you are getting a fair amount of white/blue smoke from the exhaust, you should be getting fuel, but...
I do agree the ICP numbers look low and IPR numbers look high on IPR%.
My cranking numbers are ~2,200 psi ICP and 38% IPR.
Just thinking out loud here...
Has the starter been replaced? Thinking the cranking RPM is a little low?
Again, just thinking out loud.
Old Mar 6, 2020 | 10:58 AM
  #132
Mod7.3's Avatar
Mod7.3
starting was no problem before maintance
Issue I had was a leak and coolant smell. I figured oil cooler. Also had one glow plug code a short while back, so I decided to change out glow plugs, and while there did a bunch of other maintenance. Pedestal seals Turbo seals. Fuel bowl. Ipr clean and seals(seemed fine).
Located in Calgary AB
Old Mar 6, 2020 | 11:04 AM
  #133
Mod7.3's Avatar
Mod7.3
I will get a gauge and check.
maybe spring crooked but thought all was good. Will pull apart again.
almost no exhaust coming out.
Would the IPR % be higher because enough pressure not being generated elsewhere? It closes (higher pressure) to get pressure up and opens to release pressure?
starter should be ok based on what I hear.
little to no exhaust would mean fuel an issue? If will lack of fuel pressure cause low oil pressure
Old Mar 6, 2020 | 11:16 AM
  #134
Mod7.3's Avatar
Mod7.3
Unless you are in Calgary or close, I can order one from riff raff or DoR’s. Time more of an issue now. My sons 2011 f150 broke down yesterday and it didn’t sound good, so need ex back on the road.
As I said above. Starting was fine before maintenance so I’m still hopeful it was something I did or failed do on reassembly. Possible I screwed up IPR when took it apart but based on what I’ve learned, functioning seemed ok.
Old Mar 6, 2020 | 12:02 PM
  #135
slowsure's Avatar
slowsure
I dont think its a dead give away, but I would expect to see some puffs of smoke after the longer cranks you have done to purge air.
No. Lack of fuel pressure will not cause low oil pressure.
