Rebuild Thread
Old Feb 8, 2020 | 08:01 PM
  #76
Fuzzpuss's Avatar
Fuzzpuss
Sexy stuff, Smack! Anyone else got wood?
Two questions:
1. What's the point of marking the bolts, as in the pic of the bedplate?
2. Did you use any silicone on the bedplate and oil pan gaskets?
Btw, the orifice in the banjo looks like it maybe ten or fifteen thousandths bigger than stock. Could just be the photo though.
Old Feb 8, 2020 | 08:27 PM
  #77
SmackDaddy's Avatar
SmackDaddy
Two questions:
Those are three stage torque bolts so to keep track of sequence and which torque step I’m on I mark them with a dot. The others is to make sure they all got torqued because sometimes I get sidetracked!
Yes I used a tiny bit of Motorcraft grey, none on the inside of the gasket because I did not want any squeezing out into the inside.
I think it is a little larger but not much!
Thanks! I answered your questions above!
Old Feb 9, 2020 | 07:18 AM
  #78
SmackDaddy's Avatar
SmackDaddy
Old Feb 9, 2020 | 11:07 AM
  #79
Fuzzpuss's Avatar
Fuzzpuss
As long as you remember to mark them immediately after torquing, LOL!
Old Feb 9, 2020 | 11:20 AM
  #80
SmackDaddy's Avatar
SmackDaddy
Jack caught it too, I marked them after I was done torquing and only marked two dots on the second row...he doesn’t miss much.
I am really enjoying this work, I hope the engine runs WELL for many more years after this. If not, I’m going to stick a 12 valve Cummins in it.
Old Feb 9, 2020 | 12:16 PM
  #81
TooManyToys.'s Avatar
TooManyToys.
Oh, have I had that thought! I did when the OE motor went.
Old Feb 9, 2020 | 12:28 PM
  #82
SmackDaddy's Avatar
SmackDaddy
If I didn’t have so much money tied up in new and newer parts I would have done the conversion this time instead of spending $7k on machine work and more parts. This is the last time...
Old Feb 9, 2020 | 12:56 PM
  #83
TooManyToys.
If I didn’t have so much money tied up in new and newer parts I would have done the conversion ......
I loved the 12v motor.
Old Feb 9, 2020 | 01:04 PM
  #84
SmackDaddy's Avatar
SmackDaddy
I am thinking about getting a crew cab F-250 and sticking one in it next...
Old Feb 10, 2020 | 09:39 AM
  #85
Hartwig's Avatar
Hartwig
SmackDaddy: did you had to press the spur gear (gear wheel-sorry don´t know the word) on your new cam, or did it come with the spur gear pressed on? I didn't read that.
Old Feb 10, 2020 | 09:52 AM
  #86
SmackDaddy's Avatar
SmackDaddy
I had the machine shop swap the gear to the new cam since I got the cam through them from Colt. I don’t have a press so it was a no-brainer to have them do it along with everything else. It’s on the invoice I post a photo of in the first few posts.
Old Feb 10, 2020 | 10:13 AM
  #87
Hartwig's Avatar
Hartwig
you live too far away from me!
Old Feb 10, 2020 | 10:24 AM
  #88
SmackDaddy's Avatar
SmackDaddy
Yeah if you were here in Texas we would be buddies. I’d keep you busy machining parts for me and we would be wrenching. Haha
Old Feb 12, 2020 | 01:34 AM
  #89
Hartwig's Avatar
Hartwig
Power steering hose and fitting kit from Sweeting’s
Banjo ends
Looks the same size to me, Matt said he stands behind his product and if I don’t notice better steering and brakes I can send it back...we shall see.
Had to get him to send the proper fitting for the power steering pump because this one had to be tightened up before the pulley was pressed on and almost hits with about 1/16” more to go to get the pulley completely pressed on...he’s sending an alternative fitting. I was not impressed and told him what I thought about this product.
Rebuilt hydroboost and cleaned up master cylinder in.
had you checked the stock hydroboost pressure ?
Old Feb 12, 2020 | 06:25 AM
  #90
SmackDaddy's Avatar
SmackDaddy
No I have not. How do I go about doing that?
