Coming Sync 3 update
Old Mar 25, 2018 | 12:57 PM
  #106
crewzer's Avatar
crewzer
Lightbulb
Originally Posted by troverman
No idea...mid 2017 build date on my truck.
You can check the version number in your truck's SYNC 3 system: Settings > General > About SYNC
HTH,
Jim / crewzer
Old Mar 25, 2018 | 02:27 PM
  #107
Fireferg73's Avatar
Fireferg73
Waze isn’t supposed to be released to Ford AppLink until April. IOS users won’t be able to download the app from AppLink and use it until then. I don’t know how Android Auto works since I don’t have an Android.
Old Mar 25, 2018 | 02:36 PM
  #108
wb6anp's Avatar
wb6anp
Originally Posted by 1956Fatfenders
For anyone who has installed this 3.0 update, is it build number 17276?
I had installed Version 3 in November, when news of an "unofficial version" came out. Thinking this 3.0 version that just came out was "new and improved", I tried an update tonight. After about 5 minutes of the "Updating Software..." message on the SYNC3 screen, it said my software is up to date. Hence, my question on Build Number.
Was hoping the default to FM upon startup had been remedied....
TIA!
there is a post above that explains what you may need to go the install the official release.
Old Mar 25, 2018 | 04:29 PM
  #109
SoylentSaxgod's Avatar
SoylentSaxgod
TIA!
post 81 will get you going.
Old Mar 25, 2018 | 05:16 PM
  #110
JohnnyMarauder's Avatar
JohnnyMarauder
Originally Posted by SoylentSaxgod
Good news for anyone who was stuck on the unofficial Sync 3 3.0 version.
I figured out how to get the official 3.0 to install!
Thank you! This fixed mine as well.
Old Mar 25, 2018 | 06:48 PM
  #111
1956Fatfenders's Avatar
1956Fatfenders
Thanks to you and wb6anp for pointing me in the right direction. I missed that post, and it was the answer. Update took less that 10 minutes since I was already on V3...
Old Mar 25, 2018 | 07:49 PM
  #112
geereed's Avatar
geereed
Does the text edit change work on non nav units. I tried and it starts install and then says there was a error.
Old Mar 25, 2018 | 10:38 PM
  #113
Johnboy21's Avatar
Johnboy21
Radio issue
I did the update and now my radio defaults to FM everytime I start my truck anyone else have this problem and any idea how to fix it
Old Mar 26, 2018 | 03:44 AM
  #114
wharrell's Avatar
wharrell
The issue with thus release is that no Applinks Apps work at all using USB
They. Sometimes may run for a minute or so then the system reverts to FM with all controls locked up reqiuiring a vehicle stop and restart or a master.reset
Old Mar 26, 2018 | 05:26 AM
  #115
bbmfkp's Avatar
bbmfkp
I use my Iphone's Navigation over my Sync 3 and it works great. Need to have USB plugged in though for it to work.
Old Mar 26, 2018 | 07:18 AM
  #116
rajones19's Avatar
rajones19
Planning to do the update today. Has anybody noticed if the update includes updated maps for the NAV version? I'm not sure how old the maps on my system are (truck itself is a '17), but we have found a couple places already where major interchanges have been completely rebuilt and the maps are way off, which is disconcerting if you are not familiar with the area.
Old Mar 26, 2018 | 07:36 AM
  #117
beefrob's Avatar
beefrob
I didn't see any changes in my map data. still on ver 1 15 for whatever that means. From the looks of some of the roads on the factory nav, it must mean that it was updated in 2015. Lots of road construction that was completed 2 or more year ago, but do not show up on our nav maps.
Old Mar 26, 2018 | 07:39 AM
  #118
GABAR's Avatar
GABAR
No map updates in 3.0 and there will never be any map updates this way.
The map updates will require purchasing said updates that are on a USB stick and they can be ordered from a Ford dealer for $150.00
There are a couple of forum members on here who last week purchased the above mentioned USB sticks with updated map info from a Ford dealer in GA.
I hope this info helps you out.
Old Mar 26, 2018 | 07:40 AM
  #119
beefrob's Avatar
beefrob
I am having to do a soft reset every so often since the version 3 update. I had zero issues with version 2.3. To do the soft reset hold the power button and the button with the arrow pointing to the driver side next to the M. Sorry I don't know the exact name of that button, but it beats doing a master reset or turning off the truck. Its still a pain in the hind end to have to do this after the update. Had to do it this morning to get my truck to run android auto. Either my install didn't go well, or this update wasn't ready for prime time. Does anyone know if the dealer has the ability to reinstall the update? I don't think we can from the usb.
  #120
troverman's Avatar
troverman
Seems a shame Ford charges for updates. A cheap Garmin often gives you lifetime updates. But unlike others on this site, I do find the factory GPS quite usable and functional.
