Coming Sync 3 update
Old Apr 8, 2018 | 08:30 PM
  #196
Stanbro's Avatar
Stanbro
Originally Posted by roadpilot
A couple weeks ago, I was able to update my Sync 3 from the pre-release 3.0 to the latest release version of 3.0 (18025). I did this via USB thumbdrive. File I downloaded from Ford owner's site and used was JR3T-14G381-AL.zip
Today, when my truck hooked up to WiFi, it started to download a new update. The first filename it was downloading was JR3T-14G423-CA_103602.tar.gz -- a file that was/is INSIDE of the zip file above. (I shut the truck off @ this point, as I didn't feel like waiting 2 hours and letting the truck run).
The Ford owners's site states that I'm @ the latest version of 3.0.
The Sync screen in the truck indicates that I'm at Build 18025 (the latest build).
Any idea why the truck is trying to download that file (and potentially more, if I let it run) via WiFi?
Same for me.
Old Apr 8, 2018 | 08:35 PM
  #197
System's Avatar
System
Prolocutor
Originally Posted by SDcrewzer
So, I tried the "Hit the down button" trick, and it appears to have worked.
WTF??? How did you ever figure this out?
Thanks for sharing!
Jim / crewzer
Endless nights of pure irritation... It's not a forever cure. You have to do it every time but muscle memory takes over after a few nights...
Old Apr 8, 2018 | 09:24 PM
  #198
SoylentSaxgod's Avatar
SoylentSaxgod
I love that you can turn off the display entirely for those long night drives. Nothing better than total darkness in the cab.
Old Apr 9, 2018 | 08:20 AM
  #199
~erik~'s Avatar
~erik~
I have the "default to FM" syndrome since loading the pre-release version of 3.0. Sounds like loading the official version will be a waste of time for me, since those who have done so report the same side affect of "default to FM".
Bummer. I was hoping for a cure.
Old Apr 9, 2018 | 10:59 AM
  #200
amartz02's Avatar
amartz02
I also have the "default to FM" syndrome. So this morning I used the Fordpass app to have a guide return my call. They transferred me to the In Vehicle Technology Team. I explained the issue, then was put on a brief hold while she researched the issue. The issue to Ford is no issue at all, she claims it is designed to default to FM across all of Ford Sync 3 systems, and it was simply a glitch that it was staying on Sirius in previous versions. According to this woman the only way to change this, is for many people to call in to complain and then it may get changed in a later version. Also according to this woman, there is no way to downgrade to a previous version. In case any of you would like to provide your feedback, the direct # to the In Vehicle Technology Team is 800-392-3673 then option 1 for English, option 3 for Sync, option 1 for Sync and option 2 for all other questions. I tested the options and you can press them fairly quickly without having to listen to the full option menu.
Old Apr 9, 2018 | 11:00 AM
  #201
System's Avatar
System
Prolocutor
Just FYI, you can indeed downgrade to 2.2. It will install right over 3 if you so desire.
Old Apr 9, 2018 | 12:37 PM
  #202
SoylentSaxgod
Talking
Today it finally happened. My connection to the phone timed out and it defaulted to.... SIRIUSXM!!!!
I am running current version 18025... It may be a fluke but at least it stuck to Sirius once... lol
Old Apr 9, 2018 | 01:20 PM
  #203
brandontolentino's Avatar
brandontolentino
Have you tried this? Any chance you still have the files to do it?
Old Apr 9, 2018 | 01:26 PM
  #204
System's Avatar
System
Prolocutor
I didn't but guys in the other Sync 3 thread did it when they didn't want the V3 beta due to bugs. You can't go to V2.3 as it has a version checker and won't let you go backwards. V2.2 was the last version without the version checker.
Old Apr 9, 2018 | 01:32 PM
  #205
brandontolentino
Thanks, here's the post with the link...
https://www.ford-trucks.com/forums/1...l#post17382603
Old Apr 11, 2018 | 03:03 PM
  #206
Stanbro's Avatar
Stanbro
Does anyone have a link to the Sync 3, 2.3 update files?
Old Apr 11, 2018 | 03:07 PM
  #207
Tricon's Avatar
Tricon
You can edit the XML file to trick it into thinking its whatever version you want, FYI.
Old Apr 11, 2018 | 03:12 PM
  #208
System's Avatar
System
Prolocutor
That's true and I did the same going from 3 beta to 3 official.
Old Apr 12, 2018 | 04:18 PM
  #209
wicked 2018's Avatar
wicked 2018
has anyone confirmed if they will be supporting waze app?
Old Apr 12, 2018 | 06:40 PM
  #210
tortue71's Avatar
tortue71
Originally Posted by rajones19
For those (like myself) who had updated to the unofficial release - Ford has updated the source file on their site, and it is no longer necessary to edit the autoinstall.lst file in order to get the update to install. The edits provided by SoylentSaxgod in post #81 are now contained in the download. Big thanks to SoylentSaxgod for getting this figured out ahead of Ford!
Didnt worked for me, sync detected it , said it was downloading and after a while it just said that I already had the latest version
