Coming Sync 3 update
Old Mar 29, 2018 | 01:14 PM
  #166
LPEH2's Avatar
LPEH2
Originally Posted by HRTKD
Disable ad blocker and popup blockers. Try a different browser. Just throwing out ideas. I had a similar problem in Chrome (very tight security enabled) and I think I switched to Internet Explorer (almost no security enabled).
Thank you, that did the trick. Switched over from Firefox to Chrome.
Old Mar 30, 2018 | 08:07 AM
  #167
camping nut's Avatar
camping nut
Originally Posted by beefrob
I think this is interesting, but I dont know what it means I wish Ford would share more information.
The sync 3.0 version I downloaded from the Ford site last week was JRT-14G381-AL
The version my truck tried to download this afternoon over wifi is JR3T-14G423-CA
I'm not sure what the difference is. Ford owner site still says I have the latest update
Mine is doing the same thing and is still trying today.
Old Mar 30, 2018 | 08:09 AM
  #168
camping nut
Also mine reverts to FM on start up every time, so you can add me to the list for that as well.
Old Mar 31, 2018 | 11:44 AM
  #169
dan222's Avatar
dan222
Anyone get an Error Code:LST_ERROR5 ? How to fix this?
I'm on SYNC 3 vers 2.2
Downloaded JR3T-14G381-AL
USB Stick directory shows:
auto install.lst
SyncMyRide folder - in this folder is 8 files.
DONTINDX.MSA
Thanks for any tips to help get this to update.
Old Mar 31, 2018 | 04:53 PM
  #170
GABAR's Avatar
GABAR
auto install.lst
DONTINDX.MSA
The reason i`m asking this is because of how you have the files listed above in your posting.
If you loaded them onto your USB stick in the same order on your posting, there`s a good chance that this is why you`re getting the error code. The files must be loaded onto the USB stick in the exact order they were downloaded form the Ford Owner website onto your desktop.
When I updated, the SyncMyRide folder was last not second in the download onto my desktop.
If this doesn`t work, you may have a bad USB stick, it`s not clear of other files or it`s corrupted.
I hope these tips help you out.
Old Mar 31, 2018 | 05:02 PM
  #171
HRTKD's Avatar
HRTKD
File access on a USB drive (or any other drive) is not positional. The order in which you "see" the files on the drive doesn't matter.
Old Mar 31, 2018 | 05:22 PM
  #172
GABAR's Avatar
GABAR
On the 2.1 update, I didn`t load the files in the order the were presented on my desktop and I received the same error code he mentioned. When I spoke with the people at SYNC about the error code, they walked me through the process again and they specifically told me to load/drag the files into the USB stick in the same order as they were downloaded on my desktop, which I didn`t do the first time, and the update went off without another error code and I followed the same procedure for 2.3 and 3.0 error free.
Old Mar 31, 2018 | 05:42 PM
  #173
HRTKD's Avatar
HRTKD
I've been doing this computer stuff for over 35 years and I've NEVER heard that files on a DOS/Windows based file system are positional.
Old Mar 31, 2018 | 07:40 PM
  #174
Xwild's Avatar
Xwild
I'm with Jim.. order means nothing. The folks you talked with at Sync are stupid if they think so.
Old Mar 31, 2018 | 07:53 PM
  #175
SandR's Avatar
SandR
Add me to the list. I also noticed the dash screen reverts back to the ‘towing info ’ screen every time. Can’t imagine they are related but both items started when I did the update.
Old Mar 31, 2018 | 08:46 PM
  #176
Alaskan_Warbird's Avatar
Alaskan_Warbird
If it IS that way, then the update coding is done incredibly poorly. Bright side is it could be fixed by them very quickly.
Old Mar 31, 2018 | 09:41 PM
  #177
acelefty's Avatar
acelefty
My radio reverts to FM every time I start the truck too. As far as I can tell there was no reason to upgrade from 2.3 to 3.0 and I wish I hadn't. Is there any way to file a bug report with Ford on the FM issue?
Old Apr 1, 2018 | 08:04 AM
  #178
DISLTom's Avatar
DISLTom
Did you reformat your USB stick as exFAT? I got the same error and I hadn't re-formated my USB stick.
Old Apr 1, 2018 | 08:14 AM
  #179
DISLTom's Avatar
DISLTom
My system seems to be ok after the update. Took about 22 minutes.
However, when the truck starts up, I always have it going to the home screen. And now the navigation just says "Loading Maps". I have to switch to any other screen, then go home before the maps will load.
Old Apr 1, 2018 | 10:16 AM
  #180
dan222's Avatar
dan222
Thanks
I do have it formatted as exFAT, even tried different brand media sticks.
