Can anyone who's already done the update confirm what the build number is of one is?
I did the unofficial update to Version 3.0 Build 17276 a while back and I'm wondering if the official release is the same thing or newer. Thanks in advance.
Well, darn. I had "early-adopted" version 3.0 with build 17276. It worked fine, but I was never able to get it to report back to Ford as a successful install. Anyway, I loaded up the newest version today, on a formatted thumb drive, attempted to install and after roughly 10 minutes it told me that I have the current version already installed. So then I did a master reset and tried again. Same result. So no build 18025 for me. At least build 17276 is working fine.
I have 17276 and it works, but not fine. I can't turn off my truck with the audio on Sirius and have it still be on Sirius when I restart it. It defaults to FM, and I have to manually go to "source" and re-chose Sirius.
Wonder if 18025 will load for me, and if it will fix my audio issue?
I have 17276 and I do not have this issue with Sirius. I listen to sirius 90% of the time and my truck always has it on when I start.
Well, installed the 3.0 update during my lunch break. Took about 20-25 minutes to do the complete install. Unfortunately still no Waze access it seems. They did move the heated steering wheel icon to the home screen, just as you can do with Forscan, but did not add the heated/cooled seat icons which I thought was a bit weird.
If you've already got these set to appear on the home screen with Forscan, do you have to change them back to stock before doing the 3.0 update? Thanks.
That I can't answer. I did not have them set to appear on my home screen with ForScan, although I may go ahead and add them now since it makes more sense to have them than not at this point.
I am going to attempt to downgrade from the unofficial 3.0 I am running to an official 2.3 then back up to the official 3.0. will let you know how it turns out.
I put the heated seats on my screen with Forscan a while back, no heated steering. Updated to 3.0 this morning and the heated seat is still on the screen and it still turns on the heat.
