Budget LED headlights
Old Sep 26, 2019 | 11:33 AM
  #646
RockyMtnF350's Avatar
RockyMtnF350
Originally Posted by Poncho450
I swapped every exterior bulb to LED in my 2017. Bought a 2019 2 weeks ago and put all of my 2017 bulbs into it. No complaints.
Good to hear, looking forward to getting them done over the weekend. Thanks!
Old Sep 26, 2019 | 01:57 PM
  #647
Poncho450's Avatar
Poncho450
Just be aware that once the turn signals are converted to LED, a change has to be made via FORScan or a dealer's IDS computer so that a hyperflash condition doesn't occur on the instrument cluster. The light itself will flash at normal speed, but the indicator in the cluster will flash rapidly.
Old Sep 26, 2019 | 02:23 PM
  #648
RockyMtnF350
I don't plan to do the turn signals. Just headlights, fog lights, back up and licence plate. So shouldn't need to mess with the settings. Thanks for the heads up though...😁
Old Sep 27, 2019 | 10:21 PM
  #649
RockyMtnF350
So I got everything installed...went as smooth as I could have hoped. I did the beamtech headlights and 9005's in the fog lights as well as the backup and licence plate lights. Huge upgrade over stock. Thanks for all the research and advice on install. Best money spent on lights of any vehicle I have owned.
Old Oct 2, 2019 | 03:24 PM
  #650
my_crib_too's Avatar
my_crib_too
Originally Posted by my_crib_too
Amazon has two styles of Beamtech H13 LED Headlights. Which one is most correct? Are both plug and play without having to purchase extra resistors or harnesses? Reprogramming?
Bulbs,6500K 10000 Lumens
Bulbs, 6500K 8000Lumens
This is my understanding, Clocked at 3 and 9, I need to order 4 of them, installation is about an hour without having to take the entire front of the truck apart. Anything else that I need to know about these style bulbs. I already have read about, installing the factory LED Option and LED in a non-LED light is bad.
2019 F250 Lariat.
Bruce...
So I've had the 10,000 lumens Beamtech lights for a few weeks and like them very much. I don't get flashed and I see way better at night. If you are getting older and think it's your eyes, it might be your lights.
Funny story, I took a 4 hour ride with 2,000 to 2,500 pounds in the box. I did get flashed a few times on this drive but that speaks more to weight in the truck than lights.
Bruce
Old Oct 2, 2019 | 04:03 PM
  #651
Magnolia Tom's Avatar
Magnolia Tom
Can you post a link to the fog lights you used? Did you have to modify anything or was it a straight plug and play? I believe the actual fog lights from beam tech aren't very bright.
Thanks
Old Oct 2, 2019 | 04:31 PM
  #652
Poncho450's Avatar
Poncho450
Thanks
I originally used Alla LED for fogs. Switched to Beamtech. I thought they both could have been brighter. I changed every bulb in the truck to LED on my 2017. Kept the bulbs when I traded a few weeks ago and swapped them all into the new 2019 except the fogs. They're still halogen. I don't seem to use them much anyway so it hasn't been a priority for me to switch them out.
The Beamtech fogs were H10 9145/9140/9040 replacements. I've heard here that others have had luck with another number, possibly 9005? Maybe someone could post on that.
Old Oct 2, 2019 | 05:22 PM
  #653
Magnolia Tom
I thought I saw somewhere the 9005 bulbs would work but I'm not sure if they were plug and play or not. Guess I can try to sift through all the posts of this thread
Old Oct 2, 2019 | 09:00 PM
  #654
skyak's Avatar
skyak
I did the beamtech 9005 fogs with good success.
Old Oct 2, 2019 | 10:01 PM
  #655
Poncho450's Avatar
Poncho450
Should swap right in with no problems.
Old Oct 2, 2019 | 10:37 PM
  #656
Magnolia Tom
Thanks for the insight
Old Oct 3, 2019 | 04:16 AM
  #657
BROWN DOG KTM's Avatar
BROWN DOG KTM
+1
The 9005 are actually a headlamp bulb for other applications & are Much Brighter than stock fogs.
Direct fit plug & play
Old Oct 3, 2019 | 07:23 AM
  #658
Poncho450's Avatar
Poncho450
Originally Posted by BROWN DOG KTM
+1
I kinda thought that from reading the bulb description. Thanks for the confirmation.
Old Oct 5, 2019 | 04:29 PM
  #659
RockyMtnF350
Thanks
Beamtech 9005's are plug and play for the fog lights. They are much better than the stock size.
Old Oct 6, 2019 | 10:15 AM
  #660
Magnolia Tom
Thanks. I ordered two sets of headlight bulbs and a set of 9005 for the fogs.
This is what I ordered
Amazon Amazon
Amazon Amazon
