this weekend and I have a lot FM radio interference. I see others have had the same issue and BEAMTECH sent them additional adapters (decoders) and that has fixed the issue.
For those of you that have radio issues did the decoders completely fix the radio interference issues?
I'm not really sure what the "new" version is and if it would have the same issue.
If the new version is passive cooling (no fan) and doesn't have funky flexible heat sinks I would consider it.
Originally Posted by whagen
I installed these BEAMTECH lights from Amazon. AmazonAmazon this weekend and I have a lot FM radio interference. I see others have had the same issue and BEAMTECH sent them additional adapters (decoders) and that has fixed the issue.
Thanks for the update on the info on the decoders fixing the radio issue.
This is the main reason I did not order led with my 2020. They do not generate enough heat to keep lenses clean. I live in the snow belt and don't need to add keeping headlights clear in a snow squall. Cj
this argument comes from the highway equipment market from when light signals started to switch over to LED and this was a problem. Newer signals have a ‘shake’ feature that occasionally vibrates any snow off.
this is an irrelevant issue for a vehicle moving at speed. LED lights emit so little heat that the snow should actually shed snow better since it won’t melt/stick to the lens.
my 2016 F150 Lariat with LEDs would certainly have ice build up after sitting but snow would never accumulate to the point of not letting light thru.
Lack of heat from LEDs is a moot point IMHO
It isn't an issue snow bashing in my Polaris RZR with LED headlights either
Well, I got to use my new Beamtech H13's on my drive home last night through the back country and the difference in light output is astounding. I did not adjust my headlights after installing the LED's and boy did I get flashed alot on the way home. I've only been flashed twice in 18 months with the stock halogens.
Last night I adjusted both headlights down quite a bit, so I will try the same drive tonight and see what happens. I felt like I was melting cars last night with the searing white beams lighting up the two-lane country highway. Lol.
If it is in the low 20's it usually not a issue around here but when we get heavy lake effect you need the heat to melt it away. Good friends with our road commission and sell them quite a bit so I have a good read on the led heat issue. With a quick bulb change I can have both if I want. Cj
I recently purchased the Techmax H13 LEDs from Amazon and installed them my truck, along with a pair of Beamtech H10 LED fog light bulbs. So far I'm very pleased with the increased lighting output.
I do have a ton of FM radio noise/interference. Based on the recommendations that I read here, I also ordered 7mm ferrite chokes when I ordered the bulbs. 7mm isn't the optimum size...very loose fit on the leads to the bulbs and too small to fit over the factory wiring. This is the first that I've ever used ferrite chokes but I'd assume that a snug fit would give the best performance, so I guess that I'll order some smaller (5mm ?) chokes. I've also sent an email to the only Techmax LED website that I could find, which resides on a .tr (Turkish?) domain.
I too ordered the mentioned 7mm chokes which were too big. The 5mm fit perfect and resolved the static issue.
