'07 axles under the '01 Excursion - Conversion Thread
Old Mar 6, 2018 | 09:36 PM
  #361
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Took the truck across a scale today. It weighed 8280 with me in it, and nothing but what it came with from the factory in the back. Subtract me, and you get 8080 pounds. I just found this interesting, as last time I went across that scale empty, it weighed 7800 empty. It might have gained 250 lbs from the swap...
800 lbs of scrap metal in the back, and it barely squatted 2 inches at the hitch. Rode like a dream with the 800 in the back. Unloaded it, and it was back to the "truck ride".
Old Mar 7, 2018 | 07:49 AM
  #362
Destroked 450's Avatar
Destroked 450
Intersting, mine weighed 9300 empty before the swap, haven't weighed it since, I'll have to run it across the scales to see if the front swap changed it.
Old Mar 14, 2018 | 02:41 AM
  #363
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
You swapped an engine too, so the comparison won't be the same.
Old Mar 14, 2018 | 09:06 AM
  #364
Destroked 450
We did the actual engine conversion four years ago but the salvage yard engine we installed was a piece of garbage, quart of oil every 400 miles and finally blew a head gasket.
It worked out that we were able to do the front end swap while we were building a fresh 5.9 to replace the bad engine. Adding the engine mounted air compressor and swapping the cast exhaust manifold for a stainless unit may have added 15-25 lbs.
Don't remember exactly but I think there's less than 100 lbs difference between a 5.9 12v and a 6.0 PS.
Old Mar 14, 2018 | 02:40 PM
  #365
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Interesting. If you are able to parse it all out, I think you too, will find that the coil spring radius arm set up added between added between 150 to 200 lbs, between the heavier, wider front axle, the coils, the radius arms (even though hollow) the spring buckets, the radius arm anchors on the frame, which are heavier than the rear spring shackles, the slightly heavier steering gear, the 1 foot of gussets on other side of the front frame section you swapped, the radius arm anchor castings on the axle, the heavier steering knuckle, four more lug nuts and studs, etc etc. Despite the weight of solid leaf springs and cast shock towers, the ensemble of parts from the new set up amounts to more material when melted down into ingots.
Old Mar 18, 2018 | 07:12 PM
  #366
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Just finished the spring break trip on the new axles. 1600 miles traveled in the last 7 days.
19.8 MPG on the way up there (this includes a couple of stop and go traffic jams in Waco and Dallas) hand calculated. Ride is smooth as glass on the 275/70 R18 tires and suspension on the highway. Nice and firm off the pavement, with no swaying, bouncing or jouncing around. It handles ruts and pot holes like it was made for it.
Pulled about a 6k loaded stock trailer back. Got 12.2 MPG on the return trip.
Brakes are P-H-E-N-O-M-E-N-A-L when towing. THIS IS WHY I MADE THIS AXLE SWAP A PRIORITY!! With the P3 controller working in unison, the X stops like a sports car while towing a load.
Turning radius with the trailer is priceless. Saved me in several parking lots when stopping for food/potty/rest stops.
Old May 15, 2018 | 02:53 PM
  #367
SCHECKERT's Avatar
SCHECKERT
I am about to start the axle swap on my 05 Excursion. I want to use 4.30 gears and I am having a hard time locating a rear axle with the correct gears. For the front I have 05 to 07 front axle and front clip for the truck. Can I use the rear axle from an 08 truck? I was able to find one with very low mileage and in good shape from the same yard that I will get from front parts from. Thanks.
Old May 15, 2018 | 03:01 PM
  #368
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes, you can use the 08 axles. The keys to the rear axle part of this are the driveshaft flange and the shock mounting points. Make sure you account for these two things when selecting your donor axle.
I would get the flange with the donor if you can. Knock out the u-joint it is attached to, or get the whole driveshaft. Some 08+ axles have the shock mounts welded to the axles. Make sure you have the tools/skills to get around that if you find them that way. You could get lucky, and find they are both welded on the back side of the axle. I did see one like that.
Old May 15, 2018 | 03:11 PM
  #369
SCHECKERT's Avatar
SCHECKERT
Thanks for the quick reply. I have the resources needed to deal with the one shock mount the needs to be flipped. I will try to get the flange for the axle. Was worried about this and also the wheel speed sensors not fitting from my old axles into the new axles.
Old May 15, 2018 | 03:25 PM
  #370
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Nicmike
new axles. Ride is smooth as glass. Nice and firm off the pavement, with no swaying, bouncing or jouncing around. It handles ruts and pot holes like it was made for it.
Brakes are P-H-E-N-O-M-E-N-A-L when towing. THIS IS WHY I MADE THIS AXLE SWAP A PRIORITY!! Turning radius with the trailer is priceless.
Stop it. Just stop it. You're making me hurt. (with envy).
Here's some (sour) grapes for you to snack on... have you ever had a hint of death wobble now that you're running the coils?
Seems that only the coil sprung trucks have reports of death wobble. Never hear of it with front leaf springs. Go ahead... munch on that.
(And let me know if you find any more donor parts in your friends junk yard)
Old May 15, 2018 | 03:39 PM
  #371
lwarrior1016's Avatar
lwarrior1016
Nicmike, I just want to say many thanks to you good sir. I just got my conversion done on my 99 f250 (different animal, but much the same). I have referred back to your thread a few times to check and see how you did things. You did a lot of leg work for us and documented it very well and I very much appreciate that.
Old May 15, 2018 | 04:45 PM
  #372
Stewart_H's Avatar
Stewart_H
Hmmm, I I didn't learn that term until the guys in the 7.3L forum asked how to combat it on their 4x4 trucks. I mean, I now understand it's more of a coil spring setup problem, but from all the threads going back over all these years, I figured it was a problem for our leaf sprung trucks too, just not nearly as common.
Stewart
Old May 15, 2018 | 05:53 PM
  #373
Destroked 450
Mine wobbled one time right after we got it together, we pulled it back in and rechecked all of the bolts and steering linkage, reset the alignment and made sure the track bar was good.
Hasn't wobbled since. Track bar condition is key to how well a coil spring front drives.
My old 79 F-150 was coil spring front, it never death wobbled but when the track bar bushings got loose it would wonder all over the road.
Old May 16, 2018 | 02:18 PM
  #374
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
No wobbles here after over 8k miles now. I did replace the ball joint for the track bar, though.
I'm in the middle of my cross country trip. Gonna be through KY on Friday evening.
Lots of parts at the yard. They are going fast, though. Every time I let someone from the forum drive it, they are sold on the conversion.
Old May 16, 2018 | 04:38 PM
  #375
Destroked 450
Friday evening! Ok, when you get closer send me a text about when you think you'll be getting close to Elizabethtown, take me about 45 minutes to get there.
Text 27zero nine four5 fifty five fifty1
