got chase in from weeding @ the NC house from 2 different sources of MA nature....
1. Repeated lightning strikes hitting pretty much on the neighboring properties...
2. ran into 2 nests of ground arseholes... (ground dwelling yellow jackets)
Th other year I had a nest of the beasties and it took 3 cans to kill them off because they built down into a mole tunnel.
I hope that the mole got stung a few times. This weekend they are getting a 50Lb bottle of CO2 to help them along to the light.
i ran into them on both sides of the drainage culvert that runs under the driveway.. i weed from the outer edge till i get to the driveway... when i ran into the first bunch i left for 15 mins to let them chill out... plus i ran out of string in the trimmer.. well figured id leave them alone and went to do the other side after restringing... when i got back to the other side of the culvert i ran into them there as well... these ones were worse than the first bunch...
As I understand it the CARR fire was started by a car that has some sort of malfunction and started the fire.
The fires down south were caused by a guy they nabbed for doing it. If they prove he is the one I think the
electric chair with low voltage would be a place to start if anyone dies because of this.
Yeah, they are claiming the Carr (named for the Carr Power house) was started by a travel trailer loosing a tire and dragging on the rim down the road.
I have used flea bomb and mint oil in an aerosol can that was meant for ants. It was the California solution to environmental
hazardous thingsback in 2005 when I spent a SHORT time working there. It did a good job and happened to smell not so bad.
